How to configer a router - Computers & Internet
  • 43 Answers
What exactly are you trying to configure and whats model/brand router is it?
Posted on Jan 17, 2009
How do I reset my password?
In the below example i'm setting password as cisco for enable mode & Virtual terminals of router
1)Connect to the router and follow the below steps
Router>
Router>enable
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#enable secret cisco
Router(config)#line vty 0 4
Router(config-line)#password cisco
Router(config-line)#login
Router(config-line)#exit
Router#exit
Router con0 is now available
Press RETURN to get started.
Test:
Router>enable
Password: (type cisco to enter into the router privilaged mode)
Router#
Aug 09, 2015 | Computers & Internet
My broadbans session keeps expiring why does this keep happening
it is a config issue, or a weak signal.
start with chkg signal on device.
then chk device config
then chk router config.
Sep 28, 2014 | Linksys BEFW11S4 Wireless-B Broadband...
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
I am trying to allow my cell phone to pick up wirelss from my belkin router. It's asking for a password & I can't remember what I used. How can I reset the password?
yes but you need to backup all router config. and use to router manual to help you config. then you press the reset button on the back for 5 to 15 sec, to clean all config.
and use the manual to config.
Feb 09, 2010 | Belkin (F5D7230-4) Router (587009)
I brought a Laptop (acer) I need to connect to my network but I can't remember my password. How can it get into the router to see what it is. I've called Linksys but they want to charge me 29.99
there a reset button on the back to reset config. so you must have all the router config backup on paper.
to reset router:
1st the router manual, needed for config.
2nd backup router config.(on paper)
3rd press the reset button more than 5 sec. until all lights were off (except on)
4rd reed manual the steps for 1st time config.
then config router again, and test internet connectivity and wireless security level (WPA2), change all router passw every 30days or less.
Dec 26, 2009 | Linksys Wireless-N WRT150N Router
Change IP address of Cisco 1841
once in enable mode, goto config mode. then select interface, i.e. f0/0 and then type in the following:
ip address x.x.x.x y.y.y.y where x is your IP address you wish to have and y is the subnet mask
example below:
router#config t
router(config)#int f0/0
router(config-if)ip address 10.0.0.1 255.255.255.0
hope this helps!
Oct 28, 2009 | Cisco 1841 Router
Dhcp setup on a Cisco 2851 router
Let's look at how to configure basic DHCP on an IOS-based router. For this example, we'll start off with the default configuration on a Cisco 2611 router running IOS 12.2. (The configuration should be the same—or very similar—on all IOS-based routers).
To begin, connect the router's Ethernet port to a switch, and connect the switch to a laptop, which will serve as the DHCP client.
To configure Cisco IOS DHCP, follow these steps, which include sample commands:
1.Configure an IP address on the router's Ethernet port, and bring up the interface. (On an existing router, you would have already done this.)
Router(config)# interface ethernet0/0
Router(config-if)#ip address 1.1.1.1 255.0.0.0
Router(config-if)# no shutdown2.Create a DHCP IP address pool for the IP addresses you want to use.
Router(config)# ip dhcp pool mypool3.Specify the network and subnet for the addresses you want to use from the pool.
Router(dhcp-config)# network 1.1.1.0 /8 4.Specify the DNS domain name for the clients.
Router(dhcp-config)#domain-name mydomain.com5.Specify the primary and secondary DNS servers.
Router(dhcp-config)#dns-server 1.1.1.10 1.1.1.116.Specify the default router (i.e., default gateway).
Router(dhcp-config)#default-router 1.1.1.17.Specify the lease duration for the addresses you're using from the pool.
Router(dhcp-config)#lease 78.Exit Pool Configuration Mode.
Router(dhcp-config)#exit
I hope this is helpfull for you.
Thanks
Vikrant
Oct 26, 2009 | Computers & Internet
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
Jul 24, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Computers & Internet Logo
65 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
