Question about Fellowes PS60-2 Shredder
Shreeder broken My shredder is broken,It seems me the broken of the plastic from inside, but it seems me to get repaired if the garbage from inside can be carried out, does any one provide me a manual support of fellows PS60-2. Thanks a lot. Urmil
  • JohannaD Dec 02, 2008
    My schredder won't turn on anymore. I used for a lot when I moved and now I'm in my new home, and it won't turn. Is it broken for good, or can it be fixed?
    Problem Solver:
  • 17 Answers
Here you go buddy http://www.fellowes.com/Fellowes/Materials/Documents/ps60-2_60c-2_2005manual.pdf
Posted on Aug 29, 2007
SOURCE:
P-45c shreeder motor runs but blades do not turn got all paper out but still do not turn
David,
More than likely, you have stripped the plastic gear inside. Those gears can sometimes be difficult to find and purchase. I would suggest trying to open up the top so that you can confirm if the gear is stripped. I would also suggest not putting as much paper through the shredder as they say it will handle. Hope this helps!
May 20, 2015 | Fellowes Office Equipment & Supplies
Ho do I remove the shredder to clean it
Give me more information... What kind of shredder is it?
Nov 18, 2014 | Shredder Office Equipment & Supplies
How to remove plastic cover from Kenmore disposer model 17567540
Usually, disposals are not a repairable item.
The loose shredder plate is integral with the motor shaft so they cannot come loose unless the disposal needs replacement.
Following link has part resources, manuals, and installation tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Kenmore is serviced by Sears, and you can order parts from Sears, and view some parts sheets online at their site.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 02, 2014 | Garbage Disposals
Power on and shreeder will not run. Is there a reset button?
there could be a thermal switch in the motor that is open cct check with a meter if you get continuity on motor wires
Feb 20, 2011 | OfficeMax 0M96431 Shredder
When I put a sheet in to shred, the shredder makes the normal sound but nothing happens. The same thing happens for reverse. This has occured after I had cleared a bad paper jam (there doesn't seem to be...
You dont give make or model???...however it sounds like you may have lost/broken a plastic gear inside..( the normal sound is the motor running??)...open it up to see what has been broken then contact the manufacturer.
This call was logged under "ROYAL" so if it is a Royal shredder you can contact them at 1-800-524-0799 for parts assistance once you know what is broken.
Dec 08, 2010 | Office Equipment & Supplies
Fellowes Shedder p57c broken gear
I have the same issue with my p57c shredder as well. I am purchasing another shredder. I am willing to sell my good gears if your interested. garrettsmith1983@yahoo.com
May 18, 2010 | Fellowes 3011001 Shredder
On my intimus 502 shredder the plastic coggs are
do you mean gears if you need parts call bill cook 901-565-8188
Apr 09, 2010 | Intimus 502 Shredder
Broken Dahl shredder
Go to www.fellowes.com and try using the shredder selector to find the best shredder for you. Great products and Unbelieveable customer service. I should know I am one of their CS Reps.
Feb 20, 2008 | Office Equipment & Supplies
Fellowes PS60-2 Shredder Logo
427 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
quennie732
gggg
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
