Question about Lexmark X2500 All-In-One Printer
Lexmark X2500 will not turn on; Power supply bad?
I have a Lexmark all in one, X2500, and I can't get it to come on. I think it is the power supply or AC adapter because I get AC line voltage to it but no DC out. At first I thought it was a connection problem in the back where the power supply goes. Has anyone else had this problem? Do I just need to replace it? P.N. 21G0615
  • Anonymous Feb 21, 2009
    I can't get it to come on at all. It worked one day and then the next no power!
  • Anonymous Mar 28, 2009
    one day it turned on. next time no power just completley dead
    Genius:
  • 2,120 Answers
Yes, the AC adapter is bad. Check eBay first.
Posted on Jan 17, 2009
It wont turned on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Mar 21, 2012 | Lexmark X2500 All-In-One Printer
Can not communicate with the printer lexmark x2500 wxp
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Nov 03, 2011 | Lexmark X2500 All-In-One Printer
The buttons on the control panel of my Lexmark 2500 are not working. The printer is connected and I can scan from my computer, but I cannot print. I changed the ink cartridges, but as the lights on the...
Please go through the following checklist:
Source: The Printer is Not Powering On
Jul 28, 2011 | Lexmark X2500 All-In-One Printer
How to install lexmark printer
ok! In installing X2500 lexmark printer.
1. plug the com port " USB type" at the back of the computer.
2. then power-up the printer,,
3.download the printer just follow this link http://www1.lexmark.com/products/view/All-in-Ones/Lexmark-X2500/catId=cat10004-category&prodId=3905-product
4. install the driver you download for lexmark X2500
5. then just follow the installation wizard,.. it will guide you until you finish the installation...
good luck!
Mar 15, 2011 | Lexmark X2500 All-In-One Printer
Where can I find a replacement power cord?
If you check on the power adapter behind the printer, you need a 2-prong power cord to connect to the Lexmark X2500 printer. You can check at any electronics shops around your area if it's available. But I would suggest you contact Lexmark Technical Support for assistance. They can send you one for free.
Jun 27, 2010 | Lexmark X2500 All-In-One Printer
There is something missing from back of the printer. from the user manual I believe that it is some time of power source that goes in this 1 1/2 x 3 " space. there is a plug right above this hole. Help
I believe you are referring to the power supply. It is a black box that plugs in to that hole. The power supply is where the power cord is plugged in from the power outlet in the wall. If that's missing, I strongly advise you to call Lexmark. They can better assist you with that request. You can contact them at 1-800-LEXMARK (1-800-539-6275). Hope this helps. If you need more assistance, place a comment so I can get back to it. Thanks.
Apr 16, 2010 | Lexmark X2500 All-In-One Printer
My Lexmark x2500 will not turn off.
Hello, power it off, otherwise disconnect from the main source, otherwise reconnect after 2 mins, power on and off this wiil do it
Mar 28, 2010 | Lexmark X2500 All-In-One Printer
Lexmark x2500 won't power on ,sorry but if this isn't clear enough,don't know what else i can tell you,it has nothing to do with os,there is no power going to printer,even after swapping outlets, p/s bad?...
Thru the lexmark website it looks as if the power supply may run around $15.00???
https://parts.lexmark.com/wpo-catalog/US_en/search/data_type:part/21G0615
Problem is that we don't know whether the power supply is bad or the printer itself is bad but at least you have an option.
Aug 10, 2009 | Lexmark X2500 All-In-One Printer
Printer not working at all
remove the surge protector, plug your printer direct to the wall outlet and try to power on again. try to apply a bit more pressure on the power button or try holding in down for 5 seconds, temporarily unplug the computer connection too.... if it still will not power on, try a different power cord.... if it still will not turn on with a new power cable, then check your warranty status with lexmark, this one needs to be replaced or repaired
Aug 30, 2008 | Lexmark X2500 All-In-One Printer
Power button problems
The round button should light up when printer is on. Push it and the light goes off and so does the printer.
Jun 12, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X2500 All-In-One Printer Logo
1,012 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
