Question about Abit IC7-G Motherboard
Hi lo alarm siren when playing online games
I have a Fatal1ty FP-IN9 SLI motherboard. I get the hi-lo siren when playing online games, ie cod4, cod5. As soon as I disconnect from the server the alarm stops immediately. The alarms starts after playing for approx. 15 minutes. All the cooling fans are working properly.
  • rob_craine Mar 04, 2009
    alarm sounds a various intivals then will turn off. PC still seems to run fine while alarm is sounding.Did Have the abit fan pack up so am woundering if the abit chips buggered. I ended up just pulling the cable out!
  • 53 Answers
Hi stretcharm_2,
It seems that the hi-lo siren from the mobo indicates that the cpu is over hated.
1st of all, you need to go into the BIOS/CMOS setup to check if the temperature was boosting higher that the prefix alarm. If it's low, but gone up very fast after a few minutes, you need to update to the latest BIOS firmware, as it's part of the Fatal1ty problem.
you can download the bios here, be sure to read all the instruction before you proceed to update the BIOS firmware.
you can always come back here and post a comment if you r no sure.
2nd of all, you need to check is the heatsink was fixed properly.
It's not your fault that's the fan wasn't fixed properly because the stock LGA-775 socket T heatsink's design wasn't a perfect one, and it has 4 very fragile fix-in clips. You need to check if all four clips were fixed firmly in the braket for maximum heat dicipation. It might be broken and you need to replace with another one.
You might need to replace the thermal paste to a better 1.
Please check your manual on how to diassemble the heatsink.
Good Luck,
Don't forget to rate my solution, thanks!!
Posted on Jan 17, 2009
Why doesn't it do POST?
Put a hard drive with an operating system on it.
Jan 01, 2016 | Abit Fatal1ty FP-IN9 SLI Motherboard
Fatal1ty FP-IN9 SLi mobo - works great with dual core 65nm and orig mobo bios but upgrade to quad core 45nm and bios 16 and cpu fan makes lot more noise and I then get a chaecksum error and have repeatedly...
Not everything works with everything else. There will always be compatibility issues especially with motherboards and cpus. U have different circuitry, pin configurations, power requirements, ad infinitum.
Apr 08, 2017 | Abit Fatal1ty AN9 32X Motherboard
I have a Fatal1ty FP-IN9 SLI motherboard installed in the case with a 750 watt power supply. I turn on the power, and it runs the Plextor CD writer with an XP installation CD and does not boot the hard...
If there is a disk in the cd device the bios is set up to boot up from there first. So if you have a xp OS disk in there that is what will happen . Remove the disk and it should boot from the hard drive if it is properly loaded.
Sep 09, 2017 | Abit Fatality aa8xe (MBFAA8XE) Motherboard
After testing the memory,gfx card a different hd my PC still turns off at some point once it hits the desktop,took the battery out but nothing seems to stop it shutting down.
The CPU and cooler are they installed properly? Is the Power connector pluged in correctly, both the 20pin + 4 pin and 4pin for CPU? The Black cooler over whats called the north bridge is it extremely hot? Need to keep it cool!
Nov 27, 2010 | Abit Fatal1ty FP-IN9 SLI Motherboard
Usually gets as far as the desktop before shutting down
This problem could be associated with over heating. Clean it of any dust, pay sepcial attention to the CPU cooler. It might also be a problem with software. If you turn on your PC without a hard drive installed, is it stable on a screen that says NTLDR is missing or Insert System disk. If it is stable on this screen for a long time longer than say 20 min. Then I would say that it is a software problem. If not then hardware problem!
It would be so nice to help you in person!
Installed a new processor and now it wont work
Is that an upgraded processor? If it is, then somehow, it could be its configuration problem with the older processor on software side. Your previous installation of OS remember its past processor and reporting error.
You can try fresh installation. Just for the input.
Apr 04, 2009 | Abit Fatal1ty FP-IN9 SLI Motherboard
Fatal1ty FP-IN9 SLI + Q9400 + BIOS16 = wrong CPU temp + noisy fan
I notice that the solution from myself was posted as a comment. This may prevent some from locating it. I reposted as a solution under a different name. Hopefully it would help those have the similar problem.
In addition to the following solution, you may also set the CPU core voltage to your CPU specification. My Q9400 VCore specification is 0.85~1.3625V. The BIOS auto setting sets it at 1.1625V. I just manually set it to 1.3625. CPUZ shows that C1E and stepping will lower it as necessary. It should provide the CPU more juice when it needs it, while keeps it cool when it is idle.
Ok, this is myself (Recnelis). I may find the solution for this problem. The trick is to use the beta BIOS 18 and increase the "CPU VTT Voltage" in the BIOS "SoftMenu Setup".
The beta BIOS 18 could be found here:
To make the long story short, BIOS 16 is relatively stable for Q9400 but could not recognize the CPU correctly. BIOS 18 (beta) can recognize the CPU correctly but is very unstable - random application crashes, blue screen, freeze, etc.
Here is some "history" about the issue. Fatal1ty FP-in9 SLI uses nVidia 650i SLI. If you google "nVidia 650i 45nm quad core", you will find a lot of people has the similar issue. Many websites suggest that it is because of the difference between the release version of the Intel 45nm quad core and the one sent to nVidia for testing (due to that nVidia turned off Intel's request for acquiring its SLI technology according to some rumors). Some forums suggest voltage is among those differences.
In the BIOS, you may notice that the voltage settings in the "SoftMenu Setup" are different from the actual voltages in the "PC Health Status". In my case, the actual voltages are similar but lower than the settings. One exception is the "CPU VTT Voltage". The BIOS automatically set it at 1.2V, while the actual voltage in the "PC Health Status" shows it is only a little above 1.0V. That is more than 16% drop. 1.0V is too low to keep the system stable. Guys in o/c world usualy increase the "CPU VTT Voltage" up to 1.5V to keep the system stable. Since I'm not o/c'ing my system, I do not go that far. For my particular case, when I set it to 1.31V in the "SoftMenu Setup", the actual voltage in the "PC Health Status" is 1.2V, which is what the auto setting trys to do. For your system, you may want to increase the setting one notch at a time to safely increase the actual voltage reading.
Before this tweak, my system cannot even run more than 30 minutes under BIOS 18. After this small tweak (under BIOS 18), my system becomes a whole lot more stable (no crash so far after a few days of using). It passed RealTemp torture test (using Prim95) many many times without a single hiccup. I tried to post this at least one week after the system runs in stable status; but I think some of you may still be searching for the solution.
More good news for those who want to keep the Fatal1ty IN-FP9 SLI/Q9400 for a while: I even installed Windows 7 RC (build 7100) with the new nVidia Windows 7 mobo driver and graphic driver. Everything is running smoothly so far.
Good luck to your tweaking.
Apr 02, 2009 | Abit Fatal1ty FP-IN9 SLI Motherboard
Blank screen at boot up
Sounds like you need a new motherboard how old is his computer but, before you start looking for a new board try resetting the main board jumpers maybe that will get it to work and if there are no jumpers remove the battery from the motherboard this does the same thing.
Jun 02, 2008 | Abit Fatal1ty FP-IN9 SLI Motherboard
I need a picture to follow.. help
This link will download the manual from the Abit website. It should have the parts fairly well labeled. Good luck.
Feb 21, 2008 | Abit Fatal1ty FP-IN9 SLI Motherboard
Abit IC7-G Motherboard Logo
485 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
