Question about Hitachi 46UX50B 46" Rear Projection Television
Hitachi 46UX50B high voltage transformer issue
I was just told my HItachi 46UX50B needs a new high voltage transformer, but they want $500 to fix it. The tv is 10 years old...but I found a replacement part for it for $100. Anyone know how difficult it is to change that out? I'm very handy with everything, but never messed with tv's before. Thanks for any assistance!
  • mriffle6 Jun 27, 2008
    I have a similar problem. When power button is pushed it shuts down immediately. Before turning on the power button . Inside the red led is lit with several green leds are lit. As soon as the power button is depressed all leds go out. Unplug and plug back in, all leds lite up. Though some do not seem to have the brightness as others. As soon as powe r button is depressed all go out. I need some direction in trouble shooting this problem.
    Thanks
    Mike
  • 139 Answers
Hello Bour,Its not too Bad,You gonna need a Couple of Things,Solder Wick,And a Soldering Gun,As you Pull ooff the Back of the Set.Youll find Probley 8 Screws Holding the Deflection Module(that will be the One with The High Voltage Tranformer on it(IHVT)You will have to look good on the board for all screws.....The Red lead tha come out of the IHVT Push down and Turn it should Come loose,The follow the g2 Lead to a Screen focus Bluck and pull on it it will come loose from it Note wher this lead came from,Once you have the Board loose,Turn it over and Put the Solder wick on the Connections and apply Heat,Solder will be sucked up by the Wick and you do this with each Conn,Till the IHVT is Loose(Note)Solderwick is available at Radioshack,Hope this Helps Perry
Posted on Jun 20, 2007
Hitachi model CMT-2928 Serian Number GIK 000287 after turn on the television around 5 second screen become flicker like have thunder.please help for this issue to solve thank
do you smell something at the back of your tv. if yes and still hearing the continues cricking sound its your flyback transformer it has a leak a high voltage current is arching try to replace the flyback transformer.
Oct 15, 2010 | Hitachi CMT-2195 21" TV
I have a Hitachi Ultravision 61SBX59B TV. I have white vertical lines that move across the screen from left to right. What is wrong with it, and how do I fix it?
that white line is a high voltage leak have you had this set serviced lately? one of the hv lines from the flyback transformer
is not seated or leaking you need a tech to find it not a safety issue just an anoyance
Nov 19, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Hitachi Ultravision 46UX50B Flickering/Dead Display
It is possible that you have some loose connections, but I have seen the relays in the power supply get to be intermitent and will not stay closed. Tapping lightly on the relays will usually tell whether or not they are bad.
Jun 30, 2009 | Televison & Video
Hitachi 50UX11K picture is scrambled
jansen6pack- I am currently repairing the same tv, what I found is that the video pak is going.I have checked pricing and the unit is about 500 bucks,but if you take it to a repair shop they may be able to repair it or send it away for repair. It may be worth the estimate charge. cooltekFeb.18/08
Feb 18, 2008 | Hitachi 46UX50B 46" Rear Projection...
Hitachi
TV's have a circuit that monitors the high voltage and shuts down the power if it senses something amiss.
On projection types, figure on just replacing the entire board that has the flyback transformer on it.
Hope ya fix it!
Feb 04, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 51F510 HDTV Hit by lightning
The steps that need to be taken on fixing this set start with the standby voltage requirement. Is it there? next is the low voltage loop from the transformer, also a requirement for the set to come on. ...accordianman
Nov 19, 2007 | Hitachi 51F510 51" Rear Projection...
Rear Projection... Hitachi tv
humm.. could be a crt or a high voltage problem..flyback transformer or high voltage splitter... have a tech check it out for you.
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi rear projection "61UWX10B
I was told may be problem with high voltage capacitor. not true. 1 your problem in power supply. 2 if it is ok it is due to horl.section.
Sep 14, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Flashing Screen when earmed up ?
Set should take 90seconds to "warm up" maximum. Check high voltage circuit and flyback output voltage. Bad transformer or the regulator should be suspect.
Apr 27, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi model cu4601b/k
I had this problem in a 46UX50B (I think that's the model), and it turned out to be some capacitors in the power circuit(?). After the service guy replaced those, it hasn't failed to come on since.
Apr 11, 2007 | Hitachi 46UX50B 46" Rear Projection...
Televison & Video Logo
154 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
