Question about Honda Pressure Washer PSI 3000
Honda GX 340-Used to start and run no problem, now nothing
One minute the electric start was working and now there is nothing. Brand new battery and it is fully charged. Where do I start looking first?
  • 1 more comment
  • Anonymous Feb 27, 2009
    will not fire
  • eds69s Mar 27, 2009
    GX 340 was installed on a Garden Tractor. Started and run fine before mounting engine. I have checked grounds, Battery, all connections and wires, Fuse in control box. Im not sure what happened? Engine will pull start but will not shut off with key? Any ideas?
  • ray012965 Aug 06, 2013
    honda motor uses a black with red line wire for ignition cut-out short to ground and see if motor cuts out also located by the low oil level sensor and keyswitch box must be grounded since the ground lead of switch is fastened by a screw inside the box.if you ground the lead and does not shut off you may hav an open circuit in the ignition coil especially if this engine uses a pulse generator also located by flywheel.
  • 174 Answers
I think both problems could be wiring in the key switch box. Sometimes the connectors shake loose.
Posted on Jun 28, 2009
Can i run my honda gx 340 without the balance gear
if it has one then ---NO
balance shafts are there to extend the life of the motor by removing damaging vibrations
Nov 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Gx
carburetor float is either bad or sticking.shut fuel off remove fuel bowl 10 mm bolt once removed pull pin out of float and inspect it at the same time re open fuel valve to allow fuel to push any debris the might be still in the port.re install float and test by slightly pushing the float upward and turn fuel on no fuel should drain unless you release the float if float has any fuel inside replace it if not finish putting it together and problem solved:)
Aug 22, 2014 | Honda 11 HP Engine w/electric start - GX...
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
Will a honda engine gx 340 11 hp engine fit
no it will not fit unless some modifications are made
Sep 13, 2009 | Garden
Honda GX 160 quits running at variable times.
a coil wire may be shorting so look for damage on them!
you can sleeve them or a quality electrical tape will be ok for temp measure ok
Cheers Rob.
Jul 28, 2009 | Garden
Honda gx 340 will not start
does it have a new Spark plug I have seen them fire and still be bad
Jun 30, 2009 | Air Tools & Compressors
Honda GX will not start
you must check the connection wires on your fuel pump and check the ground wire too!!
Nov 01, 2008 | 2007 Honda Civic GX NGV Sedan
Gx-6750
Guarantee, Brothers have excellent Guarantee.
Jul 07, 2008 | Brother GX-6750 Typewriter
Honda Pressure Washer PSI 3000 Logo
330 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
