Question about IBM ThinkPad T30 2366 Notebook
Laptop to projector
I want to connect my ibm thinkpad laptop to hprojector
    Problem Solver:
  • 11 Answers
I suppose you can connect your projector to VGA connector that has laptop generally on the back. If not, for example there are VGA to DVI converters, if applicable.
Posted on May 04, 2009
How do i switch to external monitor
Virtually all IBM and Lenovo ThinkPad and ThinkCenter laptops allow you to hook up an additional monitor or projector to the computer. When you add an external monitor or projector to your notebook, you can choose to view the display on the computer, on the external device, or on both the laptop and the external monitor or projector at the same time. Toggling between viewing devices is as simple as pressing a couple of keys on the keyboard.
Shut down the laptop. Plug the VGA monitor cable from the external monitor or projector into the blue VGA port on the back of the computer. Turn on the external monitor or projector first, and then the Lenovo laptop. Allow the notebook to boot into Windows normally. Press the "Fn" and "F7" keys at the same time to switch the display from the laptop to the external monitor or projector. Press the "Fn" and "F7" keys again to enable the display on both the laptop and the external display device. Press the "Fn" and "F7" keys again to display screen contents only on the laptop LCD. choose support you need http://www-307.ibm.com/pc/support/site.wss/MIGR-54305.html http://www-307.ibm.com/pc/support/site.wss/MIGR-4YQHUC.html enable tv out on thinkpad http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58625
Feb 13, 2013 | IBM Lenovo 3000 N200 PC Desktop
Unable to connect projector
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCD screenplus the external monitor or back to LCD screen only by pressing the Fn keyplus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
May 20, 2012 | IBM Lenovo ThinkPad T510 Notebook
I tried to connect my ibm thinkpad to a projector, press Fn+F7 keys but nothing being projected. Tried with a few projectors. Urgent help needed. Thanks.
If you connect the laptop before switching it on, it will default to external screen and force a picture, make sure the projector is powered up and configured to the correct resolution or you will get nothing.
Hope that helps
Feb 07, 2011 | Computers & Internet
How do you use the s-video output on a ibm thinkpad a31
first you gotta have a cable (RC) to connect from the laptop to a projector or TV. then there's a key FN + F7 to press to select the video output.
Jun 03, 2010 | IBM ThinkPad A31 Notebook
Will not connect to projector using FN F7 function
Sometimes closing and opening, (moving up & down the upper part of the pc), works. Also Think-pad, has a menu for connecting this devices.
Apr 01, 2010 | IBM ThinkPad T60 Notebook
The display on my ibm thinkpad r40 is black after initial dim ibm screen. External monitor works fine though. This happened immediately after I used my ibm with a projector this morning? Fn F7 does not...
The problem youve discribed does seem to point to your back light has failed on the laptops lcd display, i dont know exactly how this would accure just using a projector though, go into bios again and try loading factory settings.
This problem could also be the inverter if you cant make out even a slight image on the screen.
let me know what happens. thanks
Jan 19, 2010 | IBM ThinkPad R40 2681
T30 cannot connect to projector/external monitor on windows 7.
You can connect your computer to a projector to give a presentation on a large screen.First make sure the projector is turned on, and then plug the display cable from the projector into a video port on your computer.
Then press Win Key+P or run DisplaySwitch.exe and choose your preferred display.
Note:1.You can use this same procedure to connect your computer to a monitor
2.This will have no effect if you’ve only one display connected
Nov 09, 2009 | IBM ThinkPad T30 2366 Notebook
I have a problem with my ibm thinkpad notebook i want to connect my notebook hp projector how can i
When you connect a data projector or a monitor to the video output connector on the laptop you can toggle the display in various configuration by press and hold the blue Fn key and then press the F7 key (once or a couple of times as required) this key has a blue symbol of a pair of monitors.
Press it once the LCD will switch off and the display will switch to the external video output.
Press it again and the display will be on both the LCD and the external video output.
Press it again and the display will be only on the LCD.
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
Device Name
Laptops with a VGA output on the back shouldn?t need any type of ?device? for the projector to work. If its displaying an image with odd colors I would suspect a problem with the projector or the cable that connects them. The easiest way to determine if it?s the projector/cable or the laptop is try connecting it to another PC or laptop.
Jul 22, 2007 | IBM ThinkPad G40 Notebook
VGA port problem
That could be a video card driver issue. It seems that when the projector is connected, windows detects it a create another screen using up more memory. Try download a latest video card driver for your laptop http://www-307.ibm.com/pc/support/site.wss/license.do?filename=mobiles/1rd635ww.exe this is for Windows 200/XP for the IBM Thinkpad T42. If that doesn't work then you should also try updating your operating system. Hope that helps!
Sep 11, 2006 | IBM ThinkPad T42 Notebook
IBM ThinkPad T30 2366 Notebook Logo
379 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
