Question about Dell Axim X3 Pocket PC
Connecting to Internet with WiFi
I have a wireless network at home and the PDA can see it. However, I cannot connect to the internet with it. It allows me to connect to my wireless network and it shows an Excellent strength. How do I get it to connect to the Internet?
  • 2 more comments
  • jb9686 Nov 13, 2007
    I am having the same problem with mine, I upgraded the OS on it to A04 i think, and after that i couldn't get pages anymore, perfect 'network' connection, but no pages will load.
  • philmattson Feb 14, 2008
    should my axim be able to connect to my wireless network that runs through an n router of do I need a special card for that
  • ordy213 Oct 03, 2008
    I have an unsecure router through a cable modem that my compaq evo N610C detects and connects to with no problem. The problem is that my Dell axim X30 with WIFI & Bluetooth connects to the internet with the USB sync cable, and detects the network router. But once the USB is disconnected the network is still detected, but will not connect without apparenty a dial-up modem.
    How do I identify the cable modem?
  • luvslulu Oct 15, 2008
    I have the same problem. It asks for the password and I input it and it says it's not valid. The password is valid, but the Axim can't authenticate it properly.
WITH YOUR WIFI CARD IN GO TO
START ,SETTINGS,CONNECTIONS,THEN TAP ON THE WIRELESS ETHERNET.
YOU SHOULD SEE YOUR NETWORK NAME THERE.
HOLD YOUR STYLUS ON IT FOR 203 SECONDS TO GET THE
CONNECT/REMVE SCEEN.
THEN TAP ON CONNECT.
TRY THAT.
Posted on Jul 25, 2008
To phill -
Axim X3 cannot connect to Wifi, only X3ihas built in wifi
Posted on Jun 17, 2008
SOURCE:
My internet tablet keeps saying network problem when i try connecting to wifi
Please check your password and see the strength of the WI-Fi in your area. If this a wifi of your home wireless modem then check the modem and reset accordingly. switch off power for some time and restart.
If not check your tablet on another wifi to confirm this or if the configuration has gone off from the settings.
make sure that your password and the network is connected as seen on the lower taskbar .
Jun 06, 2012 | Nokia 770 Internet Tablet
Wireless Connection to the Internet
Hey mate,
So looking at your pda - it has no wlan build in, so you would need to get a wireless adapter for it.
Its pretty simple, install the adapter, plug it in, setup the wireless details of your home and your set to go.
Jul 03, 2008 | Matsunichi i-mat IP3230 Pocket PC
Tip
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
Regards,
G33k
keywords
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
I am trying to get email access. I am not able to get my email even though my PDA says that it is connecting to my Wi-Fi
First you have to ensure that the problem is not from the internet connection. Try using the PDA and the same wireless connection to open a different site which is different from the email provider. If the other site opens then you are sure that the problem is from either the phone or the email service provider.
On the other hand if it does not open then this means that the recommended settings which are expected for the PDA to work with the wifi have not been properly set to give the PDA internet access. The device might be connected to the wifi but not connected to access the internet from the device. Try setting up the PDA and this time take care of the settings.
Hope this solution has been helpful?
Jan 08, 2011 | HP iPAQ H5550 Pocket PC
Outlook and IE can't find WiFi connection. I can connect to a wireless network, but I can't get IE or MS Outlook download from it.
First of all turn the wireless radio off on the laptop, then go to the modem and the wireless router and turn them off for 2 minutes.
Turn them back on and wait a further 2 minutes for them/it to reset.
Now go to your laptop and turn the wireless radio back on again, re-connect to the wireless signal and see if you can access the net. If you can then you should have no further problems retrieving your emails or accessing the internet.
Please feel free to post back if you need to.
Good luck.
Jan 08, 2010 | Acer Aspire 5050 Notebook
I want to connect to my wireless Internet connection
If everything is working as it should. All you have to do is turn onyour Wi-Fi. You will then see a popup asking you if you would like toconnect.
You may need to add a compact flash wireless card:
  • http://wifi.aximsite.com/wifi-faq.html#_51-card
  • http://www.amazon.com/SPECTEC-Wireless-Networking-Connection-Notebooks/dp/B000BD9PBQ
You'll find a comprehensive axim wifi guide here: http://wifi.aximsite.com/
Oct 28, 2008 | Dell Axim X30 Pocket PC
How do i use my built in wireless connection to connect to the internet,please.
make sure that your wireless or wifi light is on,you may try to press Fn and F2 at the same time to enable or swith on wireless..if wifi is already on,try going to start >> control panel >> network connections,go to wireless network connection and double click it, it will give you a list of wireless network,or right click and then "view available wireless network", if you get an error that windows cannot configure wireless connection,go to start >> all programs >> loo for either dell wlan utility or intel pro wireless, by opening that app,it will also search for wireless network in range,just double click on the network name where you want to connect and you sould be connected provided that "wireless network" doesnt have encryption like wpa or wep key..if your connecting to your home network,you should have wireless router at home and wireless is enabled on the router.
Oct 05, 2008 | Dell Inspiron E1705 Notebook
Wifi not function
My Internet service provider walked me through connecting correctly. I had chosen the WEP security options and should have chosen the WPA-PSK option. Call your service provider and get them to help verify your security access codes.
Sep 26, 2008 | Palm LifeDrive Handheld
IPAQ wireless connectivity
always start with the simplest answer first so make sure you have WiFi turned on. Think back, have you changed the wireless security on your router? If so you may need to re-enter the network details or add your iPAQ's MAC address to the access control list on the router. In the bottom right-hand corner of the home screen you should have a small HP Wireless symbol, if you tap it you should get your HP Wireless control panel on screen and can 1: turn WiFi on and off, 2: manually enter the WiFi network details and 3: search for WiFi networks in range.
Aug 16, 2007 | HP iPAQ H5555 Pocket PC
WIFI for Toshiba E750
If u use a WLAN access point, you should: 1. configure your wlan router to allow internet 2. choose "WORK" in the network connections configuration dialogs. and maybe you will have to configure the proxy server too.
Sep 11, 2005 | Toshiba e750 Pocket PC
Dell Axim X3 Pocket PC Logo
869 people viewed this question
Ekse
Clive
Clive
