Question about Samsung SGH-R210S Cellular Phone
Initial Programming Code
I need my initial programming code. i accidently went to nam 2 and now it's asking for a Four digit Initial Programming code.
  • Anonymous Mar 25, 2014
    my zte z750c says it needs to be initial programming what the code
You need to call samsung at 1-888-987-4357
and they will give you a code number generated from your esn# its free so dont worry
Posted on Mar 31, 2009
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 | Cell Phones
I have a sch U740 samsung phone nam 1 code
The lock code should be the last 4 digits of your phone number or 0000.
If that doesn't work, perform an activation by dialing *228 send. Then select option 1. After this is complete your phone's lock code should be reset to the last 4 digits of your phone number.
Jul 09, 2009 | Samsung SCH-u740 Cellular Phone
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
May 08, 2009 | Samsung Hue (SCH-r500) Cellular Phone
I had my phone in my pocket during a walkathon when I pulled it out it said initial programming needed. How do I perform the initial programming?
You accidentally switched to NAM 2. Simply go to the menu; tools and settings' phone settings; NAM selection; NAM. This should help.
May 03, 2009 | Samsung Glyde SCH-u940 Cellular Phone
you can't fix it you have to get a new one...the same thing happened to me and im getting a new one
Dec 26, 2008 | Samsung SCH-U470 Juke Cellular Phone
My phone keeps on saying initial programing needed.
the solution is that you have deleted all files off your phone. so you have to take it to the verizon place so that they can reset it or if it's bad enough you can go get a new phone!!
Hope i was a help
Dec 24, 2008 | Samsung SCH-U470 Juke Cellular Phone
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
My daughter was messing around with the NAM settings switehed it fro NAM 1 to NAM 2 then the phone restarted and when it turned on it asked fro a lock code nothing she or I entered worked and it displays a...
The NAM is the internal cellphone number...every phone has 2 numbers...the one you use, and the one thats used to identify it... press *228 and then switch the NAM back to NAM 1
if that doesnt work take it back to your provider and they can reprogram it....however any contacts you had saved or music, pics, videos or downloads are gone for good...sorry
Apr 24, 2008 | Cell Phones
Initial programming needed
You should just have to dial *228 if it is a vzw phone...should regrogram it
Mar 16, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Samsung SGH-R210S Cellular Phone Logo
397 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
