I've used my camera about two weeks now and every now and then when I turn it on to take a photo, I press the shutter and it doesn't do anything. I receive two separate errors...depending on the cameras mood. It either says..."Err" which in the manual says "camera malfunction in which the solution suggests release shutter. That doesn't work and it doesn't turn off either...at the same time the "memory access card lamp" light is on. OR, I will turn it on and it will say "CHA" in which the manual says "error accessing memory card. It IS an approved card, I've tried TWO new ones now...both approved and the memory card is NOT locked on write protected. Resetting camera does nothing. Again, it won't turn off when this happens so I release the battery. That is the only way to kick it.
I've seen a couple of these now that describe similar problems with the D90. I haven't seen anything from Nikon, though. Common issues like that are normally fixed through firmware updates, but there are none out for the D90. Given that it's still under warrenty, you should take it to a local Nikon dealer and let them help you.
Manual and online (you probably know) are not too helpful on problems like this. They just tell you to put in a new or fresh charged battery.
You might try formatting the card in a PC and seeing if that clears up problems.
I've had a D70 for years and I had no problems like that at all, but I always format cards when I put them in camera, and I format on the PC every so often.
i have a samsung recoder and it will not stay charged ive purchased a battery for it and it still...
(More)
i have a samsung recoder and it will not stay charged ive purchased a battery for it and it still does not work.....
I wish to purchase a D90 but need to part exchange a D50 in mint condition.Can you advise on the...
(More)
I wish to purchase a D90 but need to part exchange a D50 in mint condition.Can you advise on the best way to go about this yours faithfully mr r lewis. 01202 576458
I have a Nikon D90 with a new Extreme III memory card. I can out in bright sun and often it won't...
(More)
I have a Nikon D90 with a new Extreme III memory card. I can out in bright sun and often it won't click even though it has focused. It gives me a flashing F--- saying that I don't have a lense attached but I have a Tamron 18-270 on. It also gives me a r17 or21 reading in the ISO/ picture count box. If I turn the camera off, take out the battery, or zoom in and out then sometimes it will take one picture and then stall again. I am loosing some great shots. Help.
How do I turn off the focus assist beam on my Nikon D90? I thought it was my red eye correction...
(More)
How do I turn off the focus assist beam on my Nikon D90? I thought it was my red eye correction light, but the icon does not appear on my display so i thought it must be the other.
sony vaio pcg-7130 not picking up wireless network despite wirelss switch being on. Router works...
(More)
sony vaio pcg-7130 not picking up wireless network despite wirelss switch being on. Router works when connected by cable. please help.
