Question about Bosch Exxcel WFO 2264 Front Load Washer
We have a bosch washing machine and cannot open the filter
We cannot open the filter to clear the pump, it will part trun but not pull out, the error message is F18  thanks
  • linda_driver Jan 17, 2009
    Thank you, I have now solved the problem by ordering a new filter first for £12,49 then taking a chance and using a set of grips, knowing if that broke it, a new was in the post.  It worked !!!!!!!!!! filter stilll in tact and cleaned out, full of coins.  We now have new spare on its way. Wasted the money in one way but cheaper than geeting in a mechanic.  Thanks so much though.
  • 135 Answers
If the filter will not unscrew there is an object preventing it from doing so. There are two options to fix this. Firstly try turning the filter one way then the other to try to dis lodge the item. This usually works after a few attempts but if not you will have to remove the large black pipe from the pump and try to remove it from there. There will be some water in this pipe!
Hope this helps.
Thankyou for using Fixya.
Posted on Jan 17, 2009
F18 is flashing on a Bosch front loader washing machine ( Logixx8 Sensitive)?
If it is a F18 error,t means that the pump out time is too long. Most likely clogged filter.
Open panel on the bottom right, drain the water out using the left hose and remove the filter plug. Have a look and clear obstructions.
That should help.
Sep 10, 2017 | Washing Machines
My Bosch washing machine showed e29. We checked the filter and now the machine won't spin the clothes.
Is the drain pump actually running, if so check for blockage at the drain end "assuming you cleared the filter", if not check the motor carbons
Sep 07, 2017 | Bosch Washing Machines
I used washing machin Bosch maxx-wfl2016.it was working well but now it take 3 hours to finish the wsshing sesion plz help to find asoluation.
Your pump is blocked so the machine can't empty the water at the end of each stage of the cycle. This is causing every stage of the cycle to take far longer than it should. At the bottom right of the machine there is a small door and behind it is the access to the pump filter (Looks a bit like a car fuel cap). Unscrew the cap and you will fin all sorts of debris in there - clear it out and all will be well. BEWARE: It is a good idea to pull the machine out and tip it bback 45 deggrees so most of the water that is remaining in the machine runs away from the filter cover, minimising the amount that goes all over your floor. You will STILL get some leakage when you open the cover, so have a towel or two to hand
Jan 28, 2016 | Bosch Washing Machines
Error e18
Could be a blockage in the hose...remove the filter cover and give a hefty blow down the end of the drain hose (give it a wipe first). If there is an obstruction along the length of the hose this should expel it. If this does not help then you may have a blockage between the drum and the pump, when the filter is out, poke your finger in the small opening in the pump housing at approx nine o'clock and see if you can feel anything. Hope this helps, good luck.
May 25, 2013 | Bosch Washing Machines
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Bosch maxx wfl2260 wont spin or drain
there will be a blockage in your "fluff" Filter cap. i could not get mine open so what i had to do was unplug the washing machine disconnected the filter from the waste and the blockage pipe and the electrics and found a bra wire i pulled it out with some long nosed pliers then the cap came off i cleared it all out connected it all back together and it worked good as new
Oct 11, 2009 | Bosch Washing Machines
Hello! My Bosch Nexxt series 300 washing machine is showing a E: 13 error and won't open. I have tried unplugging it but that doesn't seem to help.
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Aug 05, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch WFK2401 won't start error code 6
Open the panel at the bottom using a 2p coin by turning clockwise
Pull the rubber hose out of the holder and drain water into a container until stops
turn large plastic screw to the left for access to the pump
Clear away and debris bits of metal, plastic, etc that has stopped the pump.
Opposite of above to reassemble
Switch on and test... good luck!
Mar 23, 2009 | Bosch WFK 2401
Bosch Exxcel WFO 2264 Front Load Washer Logo
2,807 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
