Question about Sony DRU-820A DVD RW Dual Layer Burner
Set-up not working on sony dvd
I reformat my computer. and after that
i inserted a disk to my dvd-rw and it not work. not auto playing. pls help me
  • 489 Answers
After reformatting a computer, inserting an optical disc into a drive will not allow it to autoplay (there is no operating system to take control of the situation). If the disc is bootable and the BIOS is configured to allow booting from an optical drive, restarting the machine with the disc in it should allow the system to boot off of that disc. If this is the problem you are trying to describe, press whatever key (F2, F12, Del, etc) allows you to enter your BIOS setup program and ensure that your computer will attempt to boot from your CD/DVD drive, save your changes, and allow the computer to reboot. This should solve the issue.
Posted on May 26, 2009
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
Sony dvd +rw is not reading and writing
if you can't see the DVD writer on the "My Computer" please check the SATA/IDE cable if it is plugged correctly.. or else it's broken or check for the warranty.
Jun 13, 2011 | Sony (AW-G540A) DVD±RW Burner
In spite using DVD-R disks with the specified logo (in the case, Memorex and Sky), as I insert them in the recorder, it formats the disk but doesn't record anything on it and, when I try to eject the...
?Ÿ???¾?±?»?µ?¼?° ?µ ?²??µ?¾?±?? . ?¢????±?²?° ?´?° ??µ ??¼?µ?½?¸ ?¿?¸??°?????°???° . ?¢? ?µ ???¾?¼?¿?Ž???Š???½?° , ?¾?¿?¸???²?°?¼ ??µ , ?½?¾ ?½?µ ?µ ???°?·?¿?¾?·?½?°?²?° . ?¢????±?²?° ?´?° ??µ ?½?°?¼?µ???¸ ?½?°???¸?½ !
Nov 03, 2009 | Sony RDR-HX1000 DVD Recorder
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Pioneer dvd-rw dvr k15ra
Imy burner will burn if I go into MY COMPUTER than into MY E drive but the auto burn will not work. I do have 1dvd click and ashampoo on the computer as well, but when I put a disc into the computer it will not automtically work. I was wondering if the above programs are stopping the auto play on it or what? The burner works fine if I go to the E drive and install o burn it that way, is there some kind of a setting or something that went out of wack??
Aug 16, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Our wedding video was recorded on a DVD +RW disc on a Sony DCR-DVD108 camcorder. I did watch it on the camcorder once. I then finalized it so I could play in on my computer and DVD player. Now nothing...
It's possible because your DVD is an RW that someone could have reformatted it on accident erasing the video. If you have something important to preserve make sure you do not use an RW DVD because accidents can happen and it could get wiped out unintentionally.
Aug 01, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
SONY DVD RW AW-G170a
This is a problem with the DVD Writer model. SONY DVD RW AW-G170a has problems reading DVD+/- R/RW Discs. But there is no problem with any of the DVD+/- R/RW Dual Layer, DVD Ram or CD+/- R/RW Discs. It is the reason that this DVD Writer lacks the correct bitsetting for DVD+/- R/RW Discs. There is nothing else you could do other than replacing the wirter with some other model.
Aug 01, 2007 | Sony (1-796-293-13) Plug-In Module DVD...
Sony DRU-820A DVD RW Dual Layer Burner Logo
157 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
