Question about IBM ThinkPad T30 2366 Notebook
IBM t30 battery does not charge
My IBM T30 runs on AC power, but not battery. I downloaded and installed all the power drivers from IBM. When I check battery status on the power management screen, battery 1 appears as a dark blank on the battery status screen, not charging. I figured the first battery was bad, so I got another and the same problem occured. I have the BIOS setting setup for the battery. Could the problem actually be the lithium battery instead, or is it just a bad power connection to the battery?
  • fernweh Apr 19, 2009
    My old original battery still gets charged and shows a green battery LED while three "newly" purchased batteries only show a blinking orange LED and are taking no charge on.
  • 432 Answers
The problem could be the internal battery charger board ( a small daughter board that plugs in the the motherboard) has gone bad. You can check out this site to: Ray
Posted on Jun 21, 2007
I lost my recovery Cd. Where can I buy it?
If you cannot purchase a Recovery CD from IBM/Lenovo then you can download the device drivers from their WEB support site.
To restore your T30 back to the original Windows beg borrow etc a Windows installation CD. This CD must match the Windows version on the label on the bottom of your T30, it also displays the Product Code and this is used to install Windows on your T30.
Follow these instruction to download and install the T30's device drivers.
The same model ThinkPad can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkPad, you need to download all the drivers and install each driver until you find the right driver.
When you download the drivers, write down the device driver and it’s file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link: -
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a sub folder on C:\drivers Then install the various drivers from this folder (run the set-up file).
Jun 19, 2010 | IBM ThinkPad T30 2366 Notebook
Ibm t30 laptop has no video at start up
Try doing a hard reboot.
Unplug AC and remove battery.
Press and hold POWER for 30 seconds.
Plug in AC.
Turn on.
Upon bootup insert battery.
If this does not work I regret to say the graphics card is busted.
Apr 26, 2009 | IBM Thinkpad T30 Notebook
Battery won't charge
trying seeing the status of it in the bios! that usually tells you if the battery is faulty
it might make you caliibrate the battery to!
or it might not see it all which means its bad!
Feb 27, 2009 | IBM ThinkPad T30 2366 Notebook
Battery light yellow won't come
allow battery to complete charge (green lite)
Or change battery if chrge not completing.
(check your AC charger)
Jan 11, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad a20m
Does the battery charge AT ALL
Before buying a new battery go to my computer hardware device manager you may just need a new driver.Update restart see what happens
If not then you do need a new battery.That should solve your problem.
Nov 25, 2008 | IBM ThinkPad T30 2366 Notebook
I dont have vga driver for IBM thinkpad T30 2366)
ya i know dis site but it is of lenovi t30 drivers and the problem is that i am not geting the IBM Thinkpad Drivers..Would any buddy give me the site of downloading drivers of IBM Thinkpad T30???
Nov 15, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
T30 2366 8GA After removing AC Adaptor battery icon shows Charging and working on AC
there is a switch in the plug end to the back of your comp its like a little swinging door that when you unplug out of back of comp this switch engages battery now if you unplug just from wall its going to see these 2 things the doors not shut but i have to keep working so it sets aside the plug still recognizing it of course but running off the battery trying to still find out why the powers not there but the plug is still plugged in and it will continually search until it reaches its falt point of dead battery
its like a battery backup for your system it gets unplug but wants to know where the power is
now in reference to the little swinging door i call it its a power over relay in your comp for some reason its not closing properly to allow battery to run by self
this is usually just a switch that needs adjusted in the motherboard configuration
May 13, 2008 | IBM ThinkPad T30 2366 Notebook
Ac adapter problem
Buy a new T30 adapter off ebay, they are cheap enough and you could probably get OEM if you know where to look.
Mar 10, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 no power
I agree with you and have a link for adapters
Aug 02, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
865 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
