Question about SAMTRON 55V 15" CRT Monitor
Removing back cover of samsung monitor 15'' crt 55v
Please show me the pictures of how to pull the cover open after removing the 2 locks under the monitor
  • Stephen Wilkins
    Stephen Wilkins May 11, 2010
    monitors can hold power for days i would not attempt to open the monitor unless you are very educated on how monitors work saying so you wouldn't be on here asking for help...there is a shock warning for a reason...
I need some solutions to remove back cover for the CRT samsung monitor
Posted on Apr 11, 2009
I am having a old Samsung SAMTRON 55V (15") MONITOR. Now I isnstalled a logitech web cam. The image is not showing properly. Ghosty picture. Pl. help.
look dear ,,your monitor is not compatible to the video output of your web cam,,,,so you have either have to replace the monitor or your web cam...but problem is that if monitor is very aged then you won't get cam compatible with it...
Oct 21, 2010 | SAMTRON 55V 15" CRT Monitor
I have samsung syncMaster 551s CRT monitor. i want to open its back cover. i found only two scrow and i have remove them. but now problem is i cant remove it. plz help me.
You have to find 2 holes at the top of the plastic cover (at the front edge of the back cover) of this monitor and place a flat blade screwdriver in them and gently press to unlock the cover.
Sep 22, 2010 | SAMTRON 55V 15" CRT Monitor
I can't open Monitor
there will be 2 plastic lugs on the top of the monitor. using a flat blade screwdriver you can undo these
May 12, 2010 | SAMTRON 55V 15" CRT Monitor
How to remove control lock on 15 inch samsung crt monitor
dear harisac786,
Press and hold Menu button for 15 sec, it will unlock or lock the controller menu.
dm
Mar 14, 2010 | SAMTRON 55V 15" CRT Monitor
How to open back cover of samsung 55v moniter
Read somewhere that you need to insert a blunt screw driver in the slots between the cover and the the top of the front cover and press down lightly. hope this helps...
Feb 01, 2010 | SAMTRON 55V 15" CRT Monitor
Cleaning inside of monitor
i never heard of cleaning a moniters internals. but yeah go ahead. use a artist medium paint brush and compressed air. watch out for compassitor it will still have a live charge even if unplugged.
Feb 03, 2008 | SAMTRON 55V 15" CRT Monitor
Removing the back cover of a Samsung SyncMaster 753s
there is 2 lock on front side first remove back side lock or scrow then insert small pin pull up back cover your monitor will get open
ashok
Jan 20, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
HOW TO OPEN COVER OF OVERSIDE?
first remove back side lock then take small pin like tuser insert into small hole & Push it up side it will open
Nov 14, 2007 | SAMTRON 55V 15" CRT Monitor
Problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Oct 10, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
535 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
