Question about IBM NetVista PC Desktop
32.dll missing problem
My laptop when booting up has 32.dll file missing
    President:
  • 2,559 Answers
32.dll is not a windows file,Is any file name written before the 32?
If not it is probably part of a virus that was not completely removed.
If you can log in to windows,do a search for 32.dll and delete(DO NOT DELETE IF ANYTHING IS WRITTEN BEFORE 32)
If you can't log in,You may need to do a fresh install.
Please rate this solution.
Posted on Jan 17, 2009
Won't boot up
dll system 32 files missing install these files or format and reinstall windows
Aug 17, 2012 | Toshiba Satellite A105-S4074 Notebook
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Repaire systeme Dll 32
Insert your manufacturer operating system CD, and boot from it directly. An option should be present to repair your system's installation. This will replace the missing file.
Apr 23, 2010 | Dell Computers & Internet
Systemroot/32 /hal.dll missing
You can download hal.dll here http://www.dll-files.com/dllindex/dll-files.shtml?hal (but are you sure it's missing and not just "hidden"?)
Nov 15, 2009 | Computers & Internet
Acer Laptop Windows does not start up."system dll 32 file missing
take the drive to another computer to recover lost info then format it and reload a new install from the disk,then copy what you want back on to your computer,You will have a working system in about an hour
Hope this helps
Cheers MISTERDJ
Aug 16, 2009 | Acer Computers & Internet
I keep getting a Dell dll file error how can i fix it for free?
get the name of the dll thats missing, go here and download the dll then you unzip it to c:/windows/sys.32
here is where you get it
Jul 08, 2009 | Dell Inspiron 1420 Laptop
Missing apcmain exe.
If you have the install disk, try and boot from the disk and reinstall. To change boot order, press the key to enter bios. (different on different pc's) Common ones are f8, and delete. If you have valuable data on the Computer you dont want to lose, then use a recovery disk. (BartPe is a good one. Just google it.)
May 16, 2009 | Microsoft Windows 98 Second Edition for PC
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
IBM NetVista PC Desktop Logo
199 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
