Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher get stuck on wash
Our Bosch dishwasher get stuck on the was cycle without heating the water up
  • Anonymous Jan 20, 2009
    Stuck on the same cycle for hours
  • 54 Answers
OK.. this is a technical one... one of 3 possible problems.. most of the time its the control problem.. if you know how to take the control out.. you can check if there is a burnt mark by the 110-120v where the wires are plugged into the control.. if its burnt, you can solder if you know how or buy a new control.. most of the time the heating element and switches are not the problem... hope this help..
Posted on Jan 21, 2009
2 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: Dishwasher stuck on wash cycle and water does not heat up
The element that heats your water may be bad or the control panel(board) could be bad as well. If your machine is older than say 10 years old, it probably is the board. If you can, check the element by feeling to see if it is rusted through or has a rough feel to it in any particular area. The signal telling it to go into the rinse phase is an indication the the board is bad. Is it still under warranty?
Posted on Jan 17, 2009
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Bosch Classixx dishwasher fault
it can be a dry joint on the electronic board, or a defective thermostat, or the element, or an interrupted wire in the lower point of the door
Dec 23, 2013 | Bosch Dishwashers
Bosch she56c02uc dishwasher does not cycle, stuck on wash
If the display is stuck on 2H it often means the heater is not working. If the water is not heated, the cycle will never complete. It is possible the heating element is bad, but a more likely problem is with the control module PC board. The solution requires some basic repair and soldering skills plus the tools to do the job. Bosch recommends re-soldering the connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher Troubleshooting Tips") free download here The problem is that the circuit board copper is not heavy enough to handle the heating element current, causing the copper to heat and melt the solder connection. A better solution is to solder a short length of copper wire between the two pins to provide more copper and reduce the chance of heating as shown in the attached photo.
Nov 11, 2013 | Bosch 24 in. SHE56C05UC Stainless Steel...
Bosch dishwasher sms 4012 stuck in the wash cycle and goes on for hours without moving forward
Check the temp of the water in the machine. It could be too low and the machine is trying to heat it and cannot. If that is the case, it is either a sensor or the heating element.
Aug 11, 2013 | Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
What does a thermometer symbol with up arrow mean on an shx68
Hello Jsg5,
That symbol means that the dishwasher is heating the water, bringing it up to the required temperature to properly sanitize your dishes.
This symbol can appear during the wash and rinse cycles. It is nothing to worry about. Most dishwasher will heat up the wash and rinse water, it's just that Bosch decided to add an indicator, so users would know that any delay in the wash/rinse cycle, is a result of getting the water up to the proper temperature (typically around 140 degrees F)
Even if you've got your hot water heater or hot water supply set to a very low temperature, the dishwasher will use the built-in heating element (the drying element in the bottom of the dishwasher) to heat the water.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Bosch Integra 800 SHX68M0xUC Dishwasher
Dishwasher stalls
Water-heating cycle
Timer
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
May 31, 2009 | Bosch SHU4006 Dishwasher
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
May 26, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
94 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
