Question about Likom HD15A 15" LCD Monitor
Likom 16" wide screen LCD monitor power is but screen is blackout
I have bought a brand new likom 16" LCD wide Screen monitor 2 weeks ago. The screen has suddenly black out while i'm using it. audio is still functioning but the screen is totally blackout.power indicator LED is lighting as if it is operating normally. can anybody help me what is the possible trouble of this LCD monitor?
4 Suggested Answers
  • 125 Answers
SOURCE: The monitor cant view video
To use the external vga connector of a laptop, you have to activate it. In many notebooks it is Funtion and F7 (Fn-F7). In your notebook it may be F5 or F6, look for a monitor sigh in the F keys. The activation may sometimes rotate in sequence , ie, External + LCD, LCD, External... and so on.
Posted on May 15, 2007
HITESH
  • 20 Answers
SOURCE: Likom Futura LDF770
There may wrong setting of refresh rate. Most monitors work at 60 to 70 Hz refresh rate. Above that they tunned blank screen or out 0f range message displayed. Also check the output video signal. Please confirm technical specifications from the documentatation of the monitor.
Posted on Aug 16, 2007
nerdvana
  • 120 Answers
SOURCE: I need to know if
The max resolution for this monitor is 1024x768.
Posted on Apr 12, 2011
No picture at all. speakers work though.
gstanz52, Oh, Oh, looks like someone needs a new wide screen lcd monitor!!! What is the "date of manufacture" from the rear label???? Maybe the "black screen of death" has finally caught up with your 6 to 8 year old lcd monitor. I would guess that the internal electronic ballast circuit (inverter) has failed and will not supply 500 to 1000 vac to light-up the cold-cathode-fluorescent-lamps" any more!!! Next thing to do is go HERE: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to determine if a possible DIY refurbishment of your unit is in your future. If you want to try refurbishing unit, then do some reading in the fixya profiles of "budmrtn" "buddymc" "12fixlouie" (me) for more information and or do comment to this post. Then you should watch some video clips at YOUTUBE of owners/ technicians disassembling and repairing typical CCFL back-lit lcd monitors.
My advice to you is: Get new higher resolution Wide Screen unit. Then and only then, attempt a refurb job on F50 to keep as a working antique spare monitor. 12fixlouie
Aug 28, 2010 | HP Pavilion F50 17" Flat Panel LCD Monitor
How do i get the OSD lock to stop flashing on my screen?
mcadams_alic, Mostlikely a problem inside unit. After visiting this web site: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ you may then understand why your unit is acting "strange"!!! Your lcd monitor isn't any different than any other brand in it's basic design and operation. When very strange stuff starts appearing on the screen of any CCFLback-lit lcd monitor the first place all lcd technicians would look will be the monitor's "switch-mode-power-supply!!!! hope this helps. 12fixlouie
Jun 08, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
I bought an Asus Eee 1201HAB running windows XP for my daughter this month at Christmas from Best Buy. 2 days ago the screen went black...or unreadably dark. At the right angle in bright light I can...
It sounds very much like there is a problem with the LCD inverter. The inverter powers the backlight of the LCD panel making it light up so you can see it.
With the netbook being brand new i recommend that you take the netbook back to Best Buy and either have them replace the unit for a new one or have them arrange to send it back to Asus for repair.
The netbook should have come with at least 1 years manufacturers warranty so there should be no problem arranging for the webbook to go in.
I find it strange how a brand new netbook would fail in such a way so early in its life.
Please post back if you require anymore advice.
Regards.
Jan 16, 2010 | Acer Aspire 5610 Notebook
Gateway XHD3000 Monitor
I may be able to fix it for you
I believe the problem is in the same board that causing the strobing screen problem.
Cost is 150 to repair the problem board if it isfixable. No charge if not fixable.
You will have to pay round trip shipping for the monitor and power supply to Pennsylvania.
Ebays bammbammfran
Dec 29, 2009 | Gateway XHD3000 LCD TV
Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
Aug 22, 2009 | LG L1915S 19" LCD Monitor
Blackout
Try lowering your brightness setting below 55.Its hard to see at just the right angle.The monitor has a failsafe installed for over voltage use of the bulbs for the screen. The lights go out but your screen is still there.
Aug 11, 2007 | HP L1902 19" LCD Monitor
May 15, 2007 | Likom HD15A 15" LCD Monitor
Likom HD17A blacks out
Just check that your monitor is not set to power down(Control Panel> Power Options) and check that the 'Turn Monitor Off' Power Scheme is set to never and turn off any screensaver to see if it still goes off.
Oct 24, 2006 | Likom HD15A 15" LCD Monitor
Likom HD15A 15" LCD Monitor Logo
298 people viewed this question
Top Likom Computers & Internet Experts
David Payne
David Payne
Are you a Likom Computer and Internet Expert? Answer questions, earn points and help others
