Trying to get internet radio on my wireless sound system.
I am trying to connect my Phillips Streamium to the internet so I can get internet radio. It asks me for DNS1 ---.---.---.--- , DNS2 ---.---.---.--- , Set Gateway ---.---.---.--- , Enable Proxy yes or no if yes Proxy Address ---.---.---.--- , Proxy port -----. I cannot find any of these numbers could you please help. I have tried ipconfig but couldn't understand the numbers and what was what.
I am with Bt Yahoo and have the BT Homehub 2.0.
Start your PC; press START - RUN and in the box, type CMD and then press enter. A Window will open. Type here IPCONFIG /ALL and then press enter. You will see then some numbers including DNS Servers and Default Gateway (usually they are one and the same if you are using a router) PROXY set to NO. Should work then. Failing this, navigate using your web browser to http://www.kitz.co.uk/isp/dns.htm where you will find a list of all DNS servers - scroll down to BT and choose some from that list.
Posted on May 16, 2009
Mci900
Same problem here. Opened the case, but could not find a fuse. :-(
Feb 04, 2014 | Philips Streamium NP2900 Radio
Phillips streamium WAC700 will not boot up
i found that the bridge reservoir capacitor 68mfd 400volt on the power supply was leaking from steve
Oct 08, 2012 | Audio Players & Recorders
Describe your cannot connect my cga5722 wireless
well you need to reset your router wireless config, your isp dont do this, you need to config yourself, but i give some help. try these manual steps:
4.1 Log on the webpages
Open your Internet Browser
Enter http://192.168.2.1 in the address field
Click on GO
• The following webpage will be displayed
Note
The only default language is English.
To access the required webpage, click on the corresponding tab on
the left side of the page.
4.2
Webpages’ menu structure
The table below describes the menu tree of the webpages.
4.3 ADSL/Internet Settings webpages
4.3.1 ADSL status
Click on "ADSL Status" which is located on the left side of the screen.
SET UP WIZARD Getting started
Wireless settings
ADSL settings
Confirm
The ADSL Wireless Base Station also operates as a wireless access
point, allowing wireless computers to communicate with each other. To
configure this function, you need to enable the wireless function, define
the radio channel, the domain identifier, and the security options.
Check Enable and click "SAVE SETTINGS".
You must specify a common radio channel and SSID (Service Set ID) to
be used by the ADSL Wireless Base Station and all of its wireless clients.
Make sure you configure all of its clients to the same values.
Access Control allows users to define the outgoing traffic permitted or
not-permitted through the WAN interface. The default is to permit all
outgoing traffic.
If the signal strength of a single wireless base station is not sufficient due
to a large coverage area or attenuation due to walls, with WDS the
range of a wireless base station can be extended.
All base stations in a Wireless Distribution System must be configured
with the same radio channel, and encryption type (WEP/WPA) if that is
used.
i send a link for these steps more datailed on:
http://download.p4c.philips.com/files/c/cga5722_05/cga5722_05_dfu_eng.pdf
Jan 16, 2010 | Computers & Internet
My philips streamium will not load cds
hey this happened to mine. I contacted phillips and as it was still under warranty and they collected it, fixed it and returned it within a week. do that and see how you get on
Oct 13, 2009 | Philips Streamium SL400i
I can't connect to the internet even though the device is connected to my router using a lan cable. I have no firewall settings enabled.
Re-boot the router and also restart your system.
Check the lights on the router, they will give hint if something wrong from outside rather than your system.
Change your lan cable
Jul 11, 2009 | Philips Streamium SL400i
Internet radio will not connect to recognized WiFi
Try going into your router configuration menu, and opening the network so that any device can connect. Disable any passwords and all of that, and see if it will connect in that way. This doesnt sound like a problem with the Stiletto, rather a problem with the configuration of the wireless router. Maybe call the tech support for the router also.
Dec 19, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Streamium Remote control
Use new batteries for the remote.
May 31, 2008 | Audio Players & Recorders
Iam trying to connect my laptop to the innet. i have wrt54g router.
Hi jjroyc
Let's see if we can get your laptop connected to the Internet.
First, I have some questions and a few instructions for you.
(01) Is this a new (to you) router?
(02) Do you already have one or more computers connecting successfully to the Internet using this router?
(03) If yes, are any of them connecting wirelessly?
(04) Have you recently (at another location for example) successfully connected this laptop to the Internet? If so, did you connect it "wired" or "wirelessly".
(05) Are you trying to connect your laptop to your router "wirelessly" or "wired"?
(06) If you are trying to connect the laptop wirelessly, turn off your laptop's wireless radio and connect the laptop to the router "wired" instead (using an "Ethernet Patch Cable"). Once we've established that the laptop is capable of connecting to the Internet via the simpler "wired" connection, then we'll move on to the more complex wireless connection.
(07) Please, go HERE to download the manual for your particular router. You will need to determine the version number of the WRT54G model 1st. There are instructions there that will guide you through this.
BJ
Apr 03, 2008 | Computers & Internet
Internet connection
You trying to connect wirelessly, or wired? If wirelessly, look in your manual on how to log into the router as an admin, and change the channel its wirelessly broadcasting
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
237 people viewed this question
David Payne
David Payne
