Question about Canon PIXMA MP830 All-In-One InkJet Printer
Heavy black line
Getting a heavy black line on the underside of the printed page. Have performed all the listed cleaning functions, but cleaning the bottom roller seems to take care of it. Problem is, it keeps coming back. Shall I give up and trash the printer (one and 1/3 years old) or is this fixable?
  • jill welch Jun 21, 2007
    Inky: I don't see a foam pad under the track, just a roller and some wheels
    McCuskerCo: I have replaced the ink cartridge more than once. Is that what you mean by drum/cartridge?
    Thanks for both comments. Appreciate the effort.
  • davidduc Dec 24, 2008
    Cannon printer MP830, get heavy black strip on back of paper. after cleaning the bottom plate several times via the maintenance routine, it looks good and clean, but after few minutes, the problem returns.
    Thanks
    Dave
Run the "Clean Bottom Plate" routine under the "Maintenance" tab. I ran it about 8 times and it finally got all the gunk out.
Posted on Feb 01, 2008
I am having this same issue. I have replaced the ink cartridges (it is an inkjet not a laser so no drums as above mentioned), ran the bottom plate cleaning many times, and removed and cleaned the foam ink absorber that lays in the printhead track (it was not really dirty), lastly I cleaned the two porus absorbers at the end of the track where I assume the two black haeds "park". Any other ideas or suggestions?
Posted on May 27, 2008
  • Canon Master
  • 705 Answers
If there is a foam pad under the track that the print travels along, remove it (carefully - they tear easily) and wash it in warm soapy water. This helps on several Epson models but not sure if the Canon is the same.
Posted on Jun 21, 2007
  • Inky Fingers
    Inky Fingers Jun 21, 2007
    Sorry about my poor typing - it should read:
    If there is a foam pad under the track that the print **HEAD** travels along, remove it (carefully - they tear easily) and wash it in warm soapy water. This helps on several Epson models but not sure if the Canon is the same.
    Problem Solver:
  • 8 Answers
Have you replaced the drum/cartridge in the unit. Sounds like the drum/toner cartridge unit is defective.
  • Will McCusker
    Will McCusker Jun 25, 2007
    The unit is equipped with two black cartridges. The black for text is a large cartridge with a deep, black ink. The photo black cartridge is a smaller cartridge that contains an ink that looks more like a very dark gray. If you print any document with automatic OR manual duplex printing, the entire document will be printed using the PHOTO black ink. When you printing are you using the auto duplex mode?
SOURCE:
HP 9500 mfp: All pages aren't being stapled and it's printing a perfect black line about 2/3 down the page of all documents fed through the ADF.
Black line.....there are 2 smaller rectangular glasses that the pages are scanned through. When you lift the ADF you will see one of them next to the large glass platen, the other is on the underside of the ADF. Clean these with a wetwipe or alcohol.
The pages not being stapled, on the exit tray where the pages come out after being stapled there is a set of black rollers near there that get dirty and will not feed them into the stapler easily, you can clean these with WD40
Apr 20, 2010 | HP LaserJet 9500mfp All-In-One Printer
Printing
No black line while you scan, but it only appears while you are printing?
Mar 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
When printing on my Canon Pixma MP500, there is a dark black line down the middle of the page. As the pages print, it gets lighter and lighter, but is very dark on the first one. Any thoughts?
Ink tends to overflow at the bottom guide rollers and the roller gets coverd in ink and causes the black line!The best will be to take it to a dealer and have it cleaned!Good Luck!
Apr 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Heavy black vertical lines on back of printed page despite go through cleaning functions?
Cleaning only made it worse. The ink is coming from the cleaning assembly, and you need a shop to clean up the ink and install a mylar shield to keep that from happening again. The ink absorber gets plugged and the ink comes up thru the exit rollers.
Nov 27, 2009 | Canon Pixma MP500 All-In-One InkJet...
I have a Lexmark Optra T614 and when I print mostly black pages such as large dark graphics, I get streaky vertical lines at 3" and 5" from the left side of the portrait oriented page, and a lighter...
You need to either call a repair tech and have the printer serviced for routine maintenance or order a maintenance kit from Lexmark to do the job yourself.
Just curious, what is the page count on the printer? When was the last time the entire print cartridge was replaced?
Don
Oct 19, 2009 | Lexmark Optra T614 Laser Printer
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
May 03, 2009 | Canon PIXMA® MP530 All-In-One Printer
Hp 2420 vrtical line in page
This issue can be due to fuser. I am sure you have changed the toner cartridge.
To confirm its a fuser issue, please perform the following:
1. Try printing a configuration page from tray 1, pull the top cover, as soon as the media is 60-70% inside the printer.
This would stop the paper before reaching the fusing assy.
2. Remove the paper and check if the line exist.
If exists, fuser is not faulty.
If it does not, then transfer roller, laser/scanner assy is faulty
- If fuser is faulty, perform the cleaning page as following
1. go to configure device > print quality > create/process cleaning page
perform cleaning page 5-6 times, however, if the line is due to fuser, then fuser needs to be changed.
Let me know the next update.
- Nikhil
Nov 21, 2008 | HP LaserJet 2420 Printer
Black lines on the back of the printer page
the rollers / guides the the underside of the paper touches
Sep 11, 2008 | Office Equipment & Supplies
Black line down the page
Is the line on the front of the page or on the back? If on the back, you need to clean the platten which is the piece of plastic under the paper.
If its on the front, and you say "It lools like a rubber cover may be missing off of one of the rollers", could you upload a picture of this roller? I don't recall any covers on rollers in Canon printers.
Try this, print out a blank page. If line is still there, print out 10 blank pages. If line is still there and has not faded, this is unusual and may need servicing. There may be a problem with the encoder strip (it's a clear plastic strip with black lines running the length of the printer slightly behind the head), Try cleaning it on both sides with a little windex on a q-tip. It's delicate so be careful.
If the line looks faded after printing 10 blank pages, some ink has dripped onto something that is contacting the paper. This could be a roller, the bottom of the head carriage or even a hair or piece if dust that is stuck in the machine or on the bottom of the head. In this case, I would recommend cleaning everything. Revove the head (tell the machine you're going to replace ink, and when it moves the head into the centre position unplug the power cord.
Remove the head and clean off any dust or hairs on the bottom. Run a Q-Tip along the bottom of the carriage assembly wherever you can. Clean any accessable rollers. If you can get at it, clean the wiper on the purge unit (the unit the head sits over when it is parked), as well as the seals.
Reinstall the head and ink, close the lid, power up and retry printing.
I hope this helps. If not, there could actually be a fault with the printhead or one of the circuit boards
Dec 28, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
279 people viewed this question
Clive
Clive
old marine
old marine
