Question about JVC KD-S550 CD Player
Wiring diagram for a jvc s550 cd plaer
I havent got one and i am looking for one and it need to be installed asap!
thanks
5 Suggested Answers
  • 6 Answers
SOURCE: wire diagram for a 1998 toyota camry
Go to your local wal-mart or radio shack and ask for a radio wiring harness adapater, it connects directly to your car wiring and there i\will be no need to cut your car wires. Best of all the harness cost less than $10.
Posted on Mar 18, 2009
  • 15 Answers
SOURCE: i need a JVC KD-S550 wiring diagram for a 95
You do not need a wiring diagram....just go here and buy this harness, or purchase one at an electronics store. You will probably want to purchase an antenna extension adapter cable as well...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230398679871&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=91c6dec71250a0aad5b65db6fc08aeec&rvr_id=&ua=WXF%3F&itemid=230398679871
Posted on Dec 15, 2009
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
SOURCE: With the pioneer cd player,Can I wire the yellow
My DEH-P2000 was set up EXACTLY like that and it caused no problem. I just had to be sure to turn it OFF when I left the truck or it would drain the battery overnight.
Posted on Jan 30, 2010
Manual and wiring diagram needed for JVC KD-S6060
You may download a copy of the instruction manual here. The installation guide is appended to the end.
Jul 12, 2012 | JVC KD-S6060 CD Player
1994 toyota pickup - trying to install a jvc car stereo - all wires match up, clock will come on for a moment and then turn off. no sound either.
First of all have you tried to check the set before installing. If not test this once again. please take care to see if the main power , the standby power and the ground is given right and into the right path. make sure that the ground is taken correct. once this is right , your set must work. switch off and then you can connect the speakers. Hope this helps. good day
Jul 06, 2010 | JVC KD-S550 CD Player
My car stereo gets power but no sound is coming through speakers have tried AM, FM and CD but no sound. Not a new installation has been in car for approx. 5 years.
first check all your speakers and speaker wires for shorts. if they all check out, you may have a bad output ic inside the deck.
Jun 11, 2010 | JVC KD-S550 CD Player
Installing a new stereo. I am trying to install a ''JVC KD-R210'' in my wifes 1985 BMW 535i, replacing a Sony CDX-R79 and in the trunk is a Pioneer 12 disc cd changer that was hooked up to the system. This...
There is a line level converter that would need to be purchased to that you can get the front speakers to work with the amplifier. The stereo already has rca jacks for the rear speakers. You can connect these straight to the amplifier for it to work. Bes sure that you use the blue wire to connect to the remote turn on for the amplifiers. Once you get the line level converter you will connect the wires and connect the converter using the RCA jacks. The question would be how was the 12 disc changer connected to the system. Would need more information on the changer in order to help with that component.
Mar 13, 2010 | JVC KD-S550 CD Player
Ipod Connection on JVC KD-S550 CD Player
hi, most of the slots that plays the ipod is in front of the head unit panel, if you dont find any slots in front then it will be nowhere at the back for it will be hard to access. hope this helps, have a nice day
Feb 09, 2010 | JVC KD-S550 CD Player
I have the Kd-S550, I need the wire connections . thanks
yellow goes to positive of the battery
red goes to the acc of the ignition(0volts whn car is off 12volts when car is on)
blue goes to a amplifier remote terminal if you have on if not the tape over the exposed copper
black goes to ground
the white of the speaker is that coming from the radio or from the car?
if it is from the radio then connect it to one side of the speaker
you need the cars radio wiring instructions and radio wiring intructions and double check each wire
Jan 03, 2010 | JVC KD-S550 CD Player
I need a JVC KD-S550 wiring diagram for a 95 Saturn SC2
Dec 14, 2009 | JVC KD-S550 CD Player
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
JVC KD-S550 CD Player Logo
1,657 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
