Question about Microsoft Windows Vista Ultimate Edition
Cd drive not working
My computer is not showing cd drive icon & also when i use to switch on the cd drive it does not open
    Scholar:
  • 67 Answers
Follow this step by step Microsoft article to resolve your problem:
http://support.microsoft.com/kb/314060
If the above link doesn't work copy and paste it in internet explorer.
Posted on Jan 17, 2009
Http go acer com id 17883
  1. Press "inward" gently against the CD drive cover, if there is no eject button on it or next to it on the body of the computer.
  2. The drive should pop open and allow you to remove the CD.
  3. Failing that, click open the computer icon. The CD drive should be one of the drives showing in the window.
  4. Right click, using your mouse, on the CD drive icon.
  5. One of the options in the pop up window will say Eject.
  6. Click on it. The drive should open and allow you to remove the CD.
Aug 24, 2014 | Acer Aspire V3-572P-540V 15.6-Inch...
Can't find CD icon is missing from one computer
Windows Key-E will bring up windows explorer which should show your list of available drives.
If this doesn't show your CD drive then try removing CD from drive. Does the disc tray open? If so then reboot system without disc and try the above method to find cd-drive.
If this doesn't work you may need to involve more hands on trouble-shooting.
Thanks
Jul 22, 2011 | Staples 2x1 USB Peripheral Switch
Windows: USB Dongle shows up in Device Manager as Disk Drives: KVM vmDisk USB Device, and DVD/CD-ROM Drives: KVM vmDisk USB Device. Steals drive letters I need. How to get around this? have uninstalled...
Hi Bruce:
Sorry to hear that you are having problems. If you still want to use the device, you can assign drive letters to you other devices that do not disrupt the use of you KVM switch. Using device manager, you can change drive letters on all drives except your hard drive, usually drive 0.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
As for uninstalling the KVM device, if you want to completely remove all files from your computer, do a search (off the start menu) and search for *KVM vmDisk USB Device".
The delete all the files that are found in the search.
Let me know if I can assist you further or you need any clarification on my instructions.
Jan 12, 2011 | Avocent DSR2035 (DSR2035001) 32-port KVM...
Nothing is openning
Thank you for using FIXYA!
Does all your CDs not working when you insert them on your CDROM drive? There is a possibility that you CRRom drive's lens is failing. You can try cleaning it with a lens cleaner Or try this steps below.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
If this steps did not fix the problem i would suggest buy a new one to save you the hassle and time.
Sincerely,
stif_nec
May 22, 2010 | LG CRD 8522B Internal 52x CD-ROM Drive
HP Compaq notebook with a philips dvd-ram won't read
If you can see the CD Drive icon in My computer, it shows that at least Windows recognises the drive. If you are unable to see the drive listed in explorer (not the cd name but the actual drive icon), then please post a reply.
Other than that, you are describing what I think may be a faulty drive. If you open the case, check to see if the drive cable is in good contact with the connector and motherboard.
Feb 10, 2010 | HP Compaq Presario V6000T Notebook
I had to restore my emachine to factory settings
Open "My Computer".
Insert a "data" CD, and hold the LEFT-SHIFT key down for a minute.
Watch the icon for the CD-drive change from the "standard" icon to something specific to the data CD.
Right-mouse-click on the CD's icon, and choose "Explore",
to open Windows Explorer to view the "data" files on the CD-disk.
Dec 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
Drive no working in vista
autorun may be disabled click on windows icon (bottom left) click computer then click on your dvd drive (usuallyD) see if that opens the program on the disc if not go to device manager and click on the drive follw troubleshooting prompts
May 26, 2009 | Computers & Internet
Not showing icon of DVD Writer in My Computer
i have connected LG DVD WRITER in computer but it is not showing icon of dvd writer in computer
Jan 09, 2009 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
No datas is showing in dc rom
plz clear data is available in cd , cd is proper write or not
plz sure
Dec 19, 2007 | Microsoft Windows XP Professional for PC
DVD DRIVE OF MY HP LAPTOP
what of a laptop is it this??????
Sep 21, 2007 | Toshiba SD C2502 Internal DVD Drive
Microsoft Windows Vista Ultimate Edition Logo
24 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
