Question about Indesit K344GX Gas Kitchen Range
Set gas level oven indesit k6g21
Hi Guys i cannot adjust the gas level on my oven, i take off the knob like the manual says, and for the gas type that i am using there should be an adjustment knob at nine o'clock, but there is part of the valve body obscuring the screw. it doesnt look right and i cannot get a screwdriver anywhere near it! any ideas?
cheers Matty (Iv'e got burnt muffins) Buchanan
Well, i just pulled the whole front off and got at the adjustment screw from the timer knob hole, i guess my warranty may be bust. thanks all matty
Posted on Jan 18, 2009
My oven wont stay on but grill still ok but they work off same knob
it could be the thermocouple, you can get uiversal thermocoulpe from mmost plumbers merchants , b and q etc.fairly easy to fit ,any probs drdrop me a line
Dec 06, 2012 | Indesit Gas Cooker Spark Ingniter Unit...
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Jan 10, 2011 | Vulcan G36L Gas Range
Oven is not holding correct temp
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
When you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, and then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Let us know if you want something else please accept the solution.
Jan 02, 2011 | Maytag MGS5770 Gas Kitchen Range
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
My gas oven overheats and burns my baking. With one temperature test it was set at 300 and within thirty minutes the temperature was reaching 400 and leveling off. However, the next test with the oven at...
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
Nov 16, 2009 | Tappan TGF320 Gas Kitchen Range
Temperature setting is wrong. Stove is about 80 deggrees cooler than what the knob is set at. I am a yooper too.
If you think it is too cool, adjust the thermostat to make it hotter.
To Adjust the Thermostat:
1. Put the Oven Set knob in the OFF position.
2. Press and hold the HOUR INCREASE and the HOUR DECREASE pads at the same time for 5 seconds until the display changes.
3. Immediately, before display changes back, press the HOUR INCREASE or DECREASE pads to increase or decrease the temperature in 5 degree increments.The oven temperature can be increased up to 35°F.hotter or decreased 35°F. cooler.
If the oven adjustment is set cooler than the factory setting a minus sign “–” and the new temperature will appear in the display.
4. Wait several seconds for the control to automatically set and return to its previous setting.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained in memory after a power failure.
To Adjust the Temperature on Models with Only an Oven Set Knob
1. Put the knob in the OFF position.
2. Pull the knob off by pulling straight out.
3. Press and hold the HOTTER or COOLER button for 5 seconds to make the oven 20°F. hotter or 20°F. cooler.
When you are adjusting the thermostat, the following lights will flash indicating where the thermostat will be set when you release the
adjustment button:
OVEN ON indicates the thermostat will be set at the factory setting.
PREHEATED indicates the thermostat will be set 20°F. hotter.
CLEAN indicates the thermostat will be set 20°F. cooler.
4. After you have made the adjustment, replace the knob.
If you have any doubt please go through the manual which is given here
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/rgb745.html
Hope this will help you
Thank you
Oct 02, 2009 | Hotpoint RGB745 Gas Kitchen Range
Erratic oven temperatures adjusted the thermoatat as per instructions in manual no change
if adjustment of the screw behind the oven knob did not help:
replace the oven thermostat the part can be found at: searspartsdirect.com
Sep 05, 2009 | Kenmore Kitchen Ranges
Need instruction manual for operating Indesit Automatic Oven
I have a indesit oven and not sure what model it is because i have no manual, its silver, has 3 control knobs and six small under the small digital screen, it has 1 door at the top which is blacked out cannot see through and the bottom door is clear glass, any ideas?
Mar 02, 2009 | Ovens
Indesit K344GX Gas Kitchen Range Logo
253 people viewed this question
Top Indesit Kitchen Ranges Experts
Greg Cann
Greg Cann
Paul Carew
Owen Barnes
Are you an Indesit Kitchen Range Expert? Answer questions, earn points and help others
