Question about Zenith DVT412 System
Dvd player is producing double images
Dvd player is displaying double images {side by side}and only in black and white
    President:
  • 3,130 Answers
Go into the units system menu and change the unit to NTSC or PAL, depending on what country you live in. Good Luck
Posted on Jun 20, 2007
My DVD player only plays in black and white
Hi.
Any Incorrectly connected or defective cables can cause your DVD to display black and white images. If you Are using Component or RCA/Scart Cables follow the below steps :
You must match the colored plugs on the cable ends to the color coded jacks on your home theater and TV
Dec 30, 2017 | Televison & Video
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
How do i conect a dvd player to a Model UE32C5100QW
This will depend on the output type(s) of your DVD player.
If the outputs on the rear of the DVD player are Yellow (vodeo), Red and White (left and right audio) then you will use standard Composite RCA cables running to the A/V inputs of matching colors on the rear of your TV.
If the DVD outputs are Red, Blue, Green (video) and Red and White (audio) then you will use Component RCA cables leading to the appropriate inputs of matching color on the rear of your television.
Both of these methods will produce a standard definition image and you made need to adjust your television to get the image to display properly. You will also need to use your remote to switch to the appropriate input you used.
In some cases newer DVD players may have an HDMI output and you can use that to connect to one of the HDMI inputs on your TV. However, this will still produce a standard definition image although the DVD player or your TV may "upscale" the image to try and produce a sharper and cleaner image.
RCA cables, both composite and component, are available at retail stores such as Walmart, Best Buy or other electronics retailers. You can also find them online via Amazon, Newegg or other electronics retailers. Most shouldn't cost much and probably considerably less than a quality HDMI cable.
Feb 28, 2015 | Televison & Video
When playing DVD on panasonic plasma TV, the color is black and white
Consult the owner manual for the player (and or try it on another set) as many players have settings that can cause B&W or a single color display for the image.
Dec 02, 2012 | Panasonic Viera 50" Class 1080p Full HD 3D...
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd player split screen
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
Feb 06, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Video out problem
I own a DMR-ES20 and had that problem. Panasonic Customer Service gave me a fix that works.
On the unit itself, press STOP and PLAY at the same time for about 10 seconds. This fixed my player.
Nov 23, 2007 | Panasonic DMR-E20 DVD Recorder
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Jan 13, 2018 | Sansui VRDVD5000 DVD Recorder/VCR
Zenith DVT412 System Logo
73 people viewed this question
Top Zenith Audio Players & Recorders Experts
Greg Cann
Greg Cann
xalint1
xalint1
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
