SY-7VBA 133
Description
- 66/100/133 MHz FSB FC-PGA 370 Based ATX Motherboard
Processor
- FC-PGA 370 Pentium III Processors with 100/133MHz FSB
- Socket 370 for Celeron Processors with 66/100MHz FSB
Chipset
- VIA 693A + 686A Chipset
- 66/100/133MHz CPU FSB
System Memory
- Three 168-pin SDRAM DIMM sockets support up to 1.5GB
- PC133/PC100 DIMM support
- Provides ECC (Error Checking Correction) capability
On Board Audio Subsystem
- AC97 CODEC on board to provide audio solution.
SOYO has closed there support site many years ago.
*********** board is made by esc. the only driver they list is the s3 video.
have a look at the following web site from the link below. there are some aopen audio drivers listed for the same via chip set as yours. hopefully that fixes your problem.
http://downloadnew.org/software/P4m266-8233/
the alternative is to disable the onboard audio from the bios and install a separate sound card. they are available for around $15-20.00.
u can solve it by seeing at least you must know the chipset that added in that mainboard,,,is that via p4m266a??its easily find the driver..please follow this link : http://www.biostar-usa.com/upload/Driver/Chipset/VIA/VGA/S3DDR/Win2KXP.exe ( vga ),http://www.biostar-usa.com/upload/Driver/Chipset/VIA/Chipset/VIA_HyperionPro_V521A.zip ( chipset ),http://www.biostar-usa.com/upload/Driver//Audio/VIA/AC97/VT8235.exe ( sound ),http://www.biostar-usa.com/upload/Driver//LAN/VIA/LAN.zip ( LAN ),try it..have a nice day
http://www.viaarena.com/default.aspx?PageID=420&OSID=1&CatID=1010&SubCatID=104 hello, this link will get you the audio driver vt8235 chipset, i also recomend the 4 in one driver for the chipset. i got all my via drivers at the via arena for my jetway motherboard. make sure it i enabled in the system bios, should be by default. so good luck! and if you need more help with it-reply. please rate this solution, thank you.
go to website VIA technologies.
AC 97 driver is an audio chip driver, for your motherboard.
you,ll probably need motherboard information ( make-model-et,c ) If you just type in AC97 loads will come up. this is asking for a specific driver, for a certain Chipset on your Motherboard.
Mike @ compurepair.
can u give me the model no of ************ bord & barnd name
