Long time to boot nearly 60 times
My laptop takes too long time to boot. it takes nearly 50-60 passes in windows beigning screen
  • Anonymous Mar 31, 2014
    After hard resetting tablet boots up but is frozen at booting please wait screen
    Champion:
  • 203 Answers
RUN  The REGEDT in registry editor find these kei: COMPUTER\HKEY_CURENT_USER\CONTROL PANEL\DESKTOP in the right screen look for MENU SHOW DELAY klik on it and change the value to ZERO  type there ZERO insted of 150- 200- 400 depend of what falue is there .
Posted on Jan 17, 2009
I have a Windows 7 dell vostro 3500. And Windows won't turn on. It keeps on starting again every time on its own. It didn't go pass the "start Window Normal"....
1st time-As soon as you start computer keep mashing as fast as you can (not hold down but constant presses) till you get to advanced boot option screen. There are options to choose from.
You will have to use your arrow keys and enter key (no mouse)
First use the safe mode option.(this is in case you are fighting a virus)
turn off repeat the start with f8 key presses till it gives you the advanced boot option screen again. choose last good configuration option. If it lets you it will take a bit of time to restore do not interrupt it while it is fixing its self.
Here is a picture of what the option screen should look like.
Here How to Access the Advanced Boot Options in Windows
Dec 01, 2015 | Dell Computers & Internet
Tip
Long boot up time on MSI netbook when Kingston micro SD adapter installed
Found a strange symptom on a MSI netbook with Windows 7 Starter OS; it would take a long time to boot up. After the initial Windows splash display, the screen would go blank, and take several minutes to come back to the logon screen.
After many trials with reloading the whole drive, checking disks, finally isolated it to the presence of the Kingston micro SD adapter, but without a micro SD card in the adapter.
Without a flash card in the adapter, it apparently tries to access it regardless, and hangs things up for a long time. Removed the adapter, and it booted and shut down almost instantly in comparison.
The adapter is not a simple pass through of the micro SD card, so if there is no flash card installed, leave it unplugged, or it may slow things down considerably.
Didn't find anything on a search related to this symptom and problem, so I thought I'd note it just in case anyone else runs into this situation, maybe save them some time troubleshooting...
on Jul 13, 2010 | Computers & Internet
My hp pavilion 9000 dragon notebook takes nearly 4 minutes to bootup
You need to check what is starting up with windows. Everything that is set to start with windows will slow down the boot time. Msconfig via the run command will allow you to deselect non essential services to speed up boot times.
Nov 03, 2014 | Computers & Internet
How do i by pass the password beign used
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Aug 14, 2012 | Sun Blade 150 PC Desktop
SMART FAILURE PREDICTED ON HARD DISK 2 TOSHIBA MK2035GSS (S1) PRESS F1 TO CONTINUE. ON START UP COMPUTER GOES TO THIS SCREEN EVERY OPTION ON START UP OF F1 DOES NOT START WINDOWS AND COMPUTER RETURNS TO...
As I understand it, SMART is correct 50-60% of the time...means it's wrong 40-50% of the time.But..You can't take the risk, you have to assume something is wrong with your hard drive. So, i f you have important data there, go to a repair shop and they can save data from your hard drive and replace it, if necessary. If you want to solve it on our own, you need a boot cd with error checking. Any live boot cd with linux does that. Also, there are several live boot cds like Hiren's Boot, with rescue options.
May 11, 2011 | Computers & Internet
I buy a sony vaio pcg-f31m laptop and when i tried to format the HDD to install new windows was not accesible and i had blue screen with stop 0x000000007B or smt like it .... ! then i took it out and i...
Hi..
You nearly got it.....
Take the harddrive back out and format it on your tower,make sure it,s the right format,then place the harddrive back into the laptop and then install windows from your laptop..
Because if you install windows from your tower,your motherboard from your tower install the componants it needs to run from the windows disc,therefore it won,t run on your laptop because it,s a different motherboard...
Hope this helps...if it does please take the time to rate it,as i,ve taken the time the answer you..
Regards
Apr 02, 2011 | Sony Computers & Internet
My tv is about 2 years old. It just started burning old images into the screen and they slowly fade away but its very annoying.
Removing burn-in takes time. The best practice is to avoid creating the images.
Whatever the image is coming from has been left on screen for an extended period of time. The TV should be turned off or the source turned off when not watching.
You may find some relief by lowering your contrast (which I am suspecting is still at or near 100% as they come from the store). Bring contrast down to, say 60. Use brightness or backlight to brighten the screen if you think it is too dark with the contrast lowered. (Best picture quality is near 50, the center of the scale.)
Jun 13, 2010 | Televison & Video
Formatting HDD
Sounds like you need to run a scan disk,
at c: prompt type " scandsk /f " or chkdsk /f
This will find and fix bad sectors then you should able to format disk
Jun 04, 2008 | Toshiba Satellite A15-S127 Notebook
Laptop cer travelmate 4000
Are you getting an error?
Try power draining it by taking out the battery and ac plug, then holding down the power button for 60 seconds. It may start up but this isn't a fix.
The freezing at windows sounds like a Spyware/Virus issue.
If there is no display at all, it's probly time to buy a new one.
You can send it in for repair but by the time you get the bill you probably should have just purchased a new one.
Mar 14, 2008 | Acer TravelMate 4000WLCi Notebook
Stuck on the Windows XP Welcome Screen
One of an important file needed to boot up your laptop, or your hardware is loose. Try taking out the ram and putting it back in.
Aug 28, 2007 | Compaq Armada M700 Notebook
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
