Question about Samsung SyncMaster 170 T 17 in. Flat Panel LCD Monitor
Blinking power button
I have a Samsung syncmaster 170T 17" monitor that is unable to sync up to video signal from the computer thereby causing a blinking power button light color of amber) not the normal color of steady green. Searching around the internet I found a site that said that a blinking power button, could be a defective controller board? Any help on this one thanks.
    President:
  • 3,130 Answers
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Posted on Jun 20, 2007
SOURCE:
My monitor was not power on inspite we already corrected. and sometimes the power on was blinking in light.
I encounterred that same problem before. I just changed the video card cause it was corrupted.
Jun 18, 2011 | Samsung Syncmaster 730B 17" Flat Panel LCD...
The screen is all yellow. i am using samsung sync master 713N. it was working fine but now suddenly all white has turned light-yellow.
It does sound like a bad monitor, but first! hook a spare monitor to the computer, if okay The Samsung SyncMaster is the problem, caused by the master board which is attached behind the LCD display, the video signals are feed to the main board where the colors are balanced. To repair this would not be cost effective "cheaper to buy new" Now! if the video cable from the computer to the monitor can be detached, sub another cable just to be sure. Finally if both monitors show the same issue, the problem is in the video graphics card of the computer.
Jan 21, 2011 | Samsung SyncMaster 713N 17" LCD Monitor
My lcd monitor is not working after power failure (syncmaster 170t) .
The monitor was probably fried during the power outage due to a spike just before the power went out.
On the power brick check to see if there is an LED light and see if that is lit when its plugged in. If its not lit up then you may want to try a new power brick, if it is lit up then your monitor is a dead.
Nov 12, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Power button blinks - won't turn on
When the power light blinks, it indicates in PC mode that there's no PC signal (depending on the monitor, it could be the sync signals or a combination of sync and video.)
You SHOULD be able to hit the source button to see if the monitor then comes up to allow you to watch another source like the S-Video, Video or TV (ok, so good luck picking up any signals if you're in the US -- but you SHOULD see static and this is probably the best "quick test" for now).
If you see static... your monitor works for most part.
Where you would troubleshoot now is the cable for your PC and the connector to the monitor on both the PC and and the monitor end. These can come loose, get abused and cause solder breaks on the circuitboards within (less common but possible).
Most cable issues I see are just bad cables from extremely tight spaces bending the cable and causing wiring breaks in the connector housings. (unrepairable because of the molded cable end)
Try those out and let me know.
-Ben
Apr 18, 2009 | Samsung SyncMaster 150MP Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor problem
try running your OS on safe mode then reconfigure your monitor on the display settings and adjust the screen resolution to sync your monitor with your video card.
Sep 02, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 170 T 17 in. Flat Panel LCD Monitor Logo
553 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
