Question about Dell Studio Hybrid Desktop Computer
HYBRID CONECTED TO AN HDTV AS A MONITOR
I HAVE A HYBRID CONNECTED TO AN HDTV THROUGH A HDMI CABLE. I GOES IDDLE, AS IF IT GOES INTO HYBERNATION. HE TV SAYS NO SIGNAL AND THE WIRELESS KEYBOARD AND MOUSE DON'T SEEM TO WORK! HELP!!!!!!!!!!VB NYC I have exactly the same problem (the Hybrid seems being in hibernation, wireless keyboard, wireless mouse). The only difference is that, in my case, the hybrid is connected to a 19" LCD monitor. Thanks.
  • 103 Answers
Change the power options in the control panel so it doesn't go on standby when your in the middle of something
Posted on Sep 21, 2009
Conecting to tv
For sure there must be some tv output on your computer..... for example hdmi out..... then you need to use hdmi cable and on tv switch to correct AV input.....
another way is to connect via monitor output, but works only with LCD TVs with monitor input.....
if you would tell me what model of computer you have, than you can get better answer
Mar 24, 2014 | Packard Bell Computers & Internet
XBOX 360 HDMI Problem green/purple screen
Try the following:
Reconnect your console and TV:
  1. Remove any devices placed between the console and the TV.
  2. Connect the HDMI cable from the back of your console directly into the HDMI port on your HDTV or monitor.
  3. If you're using an audio-only A/V cable, unplug this cable and then connect the HDMI cable from the back of the console directly into the HDMI port on your HDTV or monitor.Learn more about connecting your console to a TV.
Note If your HDTV has an image-enhancement feature or any kind of digital noise-reduction feature, turn this feature off. See your HDTV user manual for instructions.
Jan 24, 2014 | Microsoft Xbox 360 Console
I can't get a signal between my Sony Blu-Ray Disc/DVD Player and Samsung HDTV monitor. They are connected via a HDMI cable. A brief message on the HDTV reads "Not supported".
First, try to reset resolution of HDMI Sony BD output.
Unplug HDMI cable from TV and change to Component connection to reset BD output resolution.
Than after you entered to resolution menu, choose to standart resolution 720 or 480 i.
If above methode working, try to reconect HDMI cable again to HD TV.
If any problem with picture or still "Not Supported" messege appear, i suggest to change HDMI cable first.
i hope its work.
Mar 14, 2011 | Televison & Video
How do I connect my asus laptop to my sansui hdtv hdmi? what cords do I need and do i need to do something special with my computer?
No,try websites like Ebay.com or Amazon.com to buy a HDMI cable.Plug the HDMI cable in ur computer USB hub and the other side of the HDMI cable to the tv HDMI hub.Go into tv menu goto the tv find the wright input of the HDMI cable is in ur tv input there it is ur LCD Tv as a computer monitor.
Nov 12, 2010 | Sansui HDLCD3210 32 in. LCD TV
How do I connect my hdtv cable box to the tv/monitor. There is no hdmi input on the tv.
Your setup has a TV/Monitor and a audio/video box. The A/V box is connected to the TV and other source inputs connect to the A/V box. Hookup your cable box to the A/V box either using component video (green, blue, red) RCA cables from cable box outputs to the A/V box inputs OR the A/V box also has a DVI/HDMI input jack which may work using a HDMI cable.
Select the proper source.
Aug 26, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Connect denon 1709 to my tv
I will assume that your TV is an HDTV capable unit. Since I also would assume that the Denon AV1709 is properly setup in your listening room/Home Theater. You will need to purchase one HDMI cable from the Denon to the TV input. This cable must be long enough to go from the Denon to the TV with length to spare. The more money spent on a better quality HDMI cable will pay dividends on how much better the screen will appear. On the back of the Denon is an HDMI output labeled "Monitor Out" that the new cable will go into, and the other end of the cable will go into the TV input labeled HDMI. On the remote I would search for a button labeled "Input" or "Source" and on the screen I would look for the input that would reflect the same input you put the HDMI cable into in the TV. If your TV doesn't have HDMI inputs see if it does have "Component input" on the back The information will be similar but will reflect the different Input and Outputs you may need to use. The cables will be more complicated but they are color coded just for you. Red goes to Red, Blue goes to Blue, Green Goes to Green. Enjoy Re-Post if you need further information.
Sep 16, 2009 | Denon AVR-1709 Receiver
Your HDTV does not support HDCP
This is normal in HD 4250.Problem is ( box software).You need to disconnect HDMI cable from the box,or leave TV "ON" during recording.
Apr 04, 2009 | Sony Playstation 3 (PS3) Console
Connecting Gateway HDMI TV to Playstaion 3
If your PS3 has HDMI capability and the monitor has HDMI capability, it should work as long as the monitor can match to the specs of the PS3.
I am not sure, but I think the PS3 required the capability of 1080p from the TV set. Make sure that your TV is able to see 1080p.
For HDTV, the standard A/V cable set is of no use. That is why your monitor probably does not support the standard A/V format.
Jerry G.
May 18, 2008 | Gateway FPD2275W LCD Monitor
Dell Studio Hybrid Desktop Computer   Logo
134 people viewed this question
Alun Cox
