Question about Gateway MX7118 Notebook
Bypassing broken start button
Can you start a Gateway MX7118,bypassing the start button?
  • Kevin Hughes May 11, 2010
    do you mean the power button? the start button is the windows start shortcut located next to the space bar on most keyboards....
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
Gateway mx7118 wont start wirt added ram. I want to add a 1gb stick od ddr2700 ram but it wont start with the mamory installed, just sits there with a blinking cursor
If you are using 2 different types of ram (from different mfg.,same brand may not work if made to diff specs) it will not work.
Mar 02, 2010 | Gateway MX7118 Notebook
Latptop starting problem
Do any lights come on at all? If it seems to come on but does not render a picture this is most likely a memory issue. Also, to your knowledge has the system been dropped, opened up, hardware added, or anything of that nature? Do the power lights come up when you plug in the power adapter to show the battery is charging? Have you tried booting up without the battery and just the power adapter plugged in?
Good Luck,
Jesse
Jan 07, 2010 | Gateway MX7118 Notebook
SOUND PROBLEM
Here is the Gateway site>
You will find all the drivers on this page..
http://support.gateway.com/support/drivers/search.asp?param=mx7118&st=kw
Jun 24, 2009 | Gateway MX7118 Notebook
SC1485ITC 0534 ZA5150690 WHAT IS THIS ? I NEED THIS PART FOR MY LAPTOP BUT NOT ABLE TO FIND IT .
Get on a friend's computer and go to http://support.gateway.com/support and enter your information on the website, and it should be able to give you specific information about your laptop. If nothing else, try calling Gateway and ask a representative to help you.
Apr 17, 2009 | Gateway MX7118 Notebook
Start button on Gateway MX7118 is broken
No there is no other option wherin u can start the machine................u need to use the start button..................Sameeraryan
Jan 17, 2009 | Gateway MX7118 Notebook
Gateway mx7118 says drive has corrupt files cant repair using win
You don't need to change or buy another hard drive, unless you want to install a larger size hard drive.
Boot up with the Windows CD and reinstall Windows.
Jan 07, 2009 | Gateway MX7118 Notebook
Fix the on button on a Gateway laptop (MX7118)
lay down the screen flat
then get the two screws under the power bar
lift up power button bar carfully,you will see ribbon cable connected to the mother board with little brown clips, one on the power button also, this ribbon cable is very thin, and you probably will see the cracks with maginfy, order ribbon cable on ebay
Jan 03, 2009 | Gateway MX7118 Notebook
Hard disk upgrade for Gateway mx7118
check Gateway's support for possible help here. Most laptops can be upgraded substantially, RAM or Hard drive.
Gateway's site- I didn't see any BIOS upgrades. http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=10651&os=&type=
Perhaps someone on this site has made such an upgrade and can give you a definitive answer.
Jun 18, 2008 | Computers & Internet
Gateway MX7118 Notebook Logo
169 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
