Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
HELP! Fire Hazzard!
While watching, my TV started crackleing, the screen went black, smoke and sparks shot out the back last night. We imeadiatly unplugged from surge protector. (The TV turned off automaticlly) When plugged back in, and turned on again, the same thing happened. About a month before the fireworks, the screen would go black a few times and then shut itself off. After a minute I could turn it back on. I called GE and they asked how old the surge protector was I and I said probably 2 years (as old as th TV) So I purchased a new one and TV worked fine for 2 weeks, then shot sparks. Please help! I have a feeling this could be an expensive fix and need to know if I should just buy a better TV.
    President:
  • 3,130 Answers
It sounds like your focus/screen block, the flyback transformer, or maybe a CRT anode lead is leaking high voltage. This could be a serious problem, or could be a simple one. You should not attempt this repair unless you know all of the high voltage safety issues involved with this TV set. Good Luck
Posted on Jun 20, 2007
SOURCE:
My Vizio LCD TV went out. Its just a black screen. The Vizio symbol turns on and off but no picture and no sound. It sounds like its similar to most peoples issues on here. How do I know if its my mai
There could be a few things that would cause this. I would suspect that you have a problem with either the power supply board or the main board. Based on my experience, the main boards go before the power supplies. What is the model #
Jan 26, 2013 | Vizio E550VA 55 in. LCD TV
Screen went black smoke coming from back tv is 2007 according to back sticker still have sound
Smoke = overheating = big short = big failure of a part.
Unplug the tv immediately - you don't want t set your house on fire - and call a repaiman. Since the tv has been smoking then the damage will be extensive - a lot of parts, even entire boards, have been damaged. Te repair will be costly.
Oct 05, 2010 | Element Electronics FLX3210 32 in. LCD TV
My Screen Went Black and i can only hear Audio.
Ur tv the LCD inverter board it dead.This board it help to get a backlight to ur LCD screen panel go through the Tuner board to produre a picture.Replaced this LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 26, 2010 | Sanyo 42 in. LCD TV
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 17, 2010 | Ovens
Screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Oct 11, 2009 | Philips 47PFL3603D LCD TV
GE D52GW12 - Manufactured in 9/2004
dear one
your pl check following point's
1 check mains power plug is all right
2 if you can check by changing the main's coard
if your problem not solved call the service persone the probleam is with main poer supply in your tv.
thank you
Jan 24, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Flashing
Pop and flash meaning that the picture turns on and off? Many people's tv eventually just turns off all together. Furthermore, if you notice a crackling sound, it isn't just the sound of the tv turning off, it is the sound of sparks and flames emitting from the back of the television. Take notice of this as it is a fire hazzard. If you do notice this, please report the problem to the consumer product safety commision. I beleieve this common problem with large sparks and flames warrants a recall.
https://www.cpsc.gov/cgibin/incident.aspx
Dec 02, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Akai PT5598HD 55 in. Rear Projection
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
152 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
