Emmerson HDTV f32
Emmerson 32" flat panel HDTV will not stay on. Green light comes on HDTV shows on screen for about 1 second, then it shuts off and red standby light comes on. I need help this tv is less than a year old. It just started doing this.
Thanks,
P Callaway
  • 2,322 Answers
The failure with this LCD might be due to a failing power supply or backlight inverter board. Since your TV is less then a year old, I would suggest to call the manufacturer to get it fix under warranty.
Good Luck.
Posted on Jan 18, 2009
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My 42'' regza..won't come on. there is power but no picture. the green light will not stay on green. what might be the problem?
Sounds very much like a screen fault to me - the set powers up and senses the fault so shuts down again- seen this fault a fair bit I'm afraid.
Feb 04, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Insignia? 37 720p Flat Panel LCD HDTV will not
Power-cycle the unit (turn it off and unplug for several minutes). If you're unable to power the unit on successfully, the TV probably requires repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 03, 2010 | Insignia 37" LCD Flat-Panel HDTV
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen
lamp is burned out cost around 200 dollars. easy for comsumer to replace them self. dont get a generic lamp
Jun 04, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Rca l32wd22 blackscreen
princess_dc6,
Just recently, I was told how to get another tv.
You find a good TV service centre and ask them to fix it. If they cant you take the work order from your tv sc and call 1-877-297-8391.
You will get yourself a tv
Jun 01, 2009 | RCA L32HD31 32 in. LCD HDTV
LG Flat Screen Problem
since when have you experienced the problem? does the tv still turn on or not...?
Aug 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
