Question about Toshiba TDP-ET20U DLP Projector
TDP ET20 projector remote not working
The above remote has suddenly stopped working. The bulb seems fused.
My questions:
1. Where can I get a replacement. This projector model is out of production and I can't find the remote on the web.
2. Can anyone tell me the remote model number?
3. Can I find out this remote's code so that I may use a universal remote.
Thanks
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
  • 320 Answers
SOURCE: Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Posted on Mar 06, 2009
  • 74 Answers
SOURCE: Thin black lines: projector TDP-ET20
Do a factory reset to the projector. In my experience that fixes alot of image problems.
Posted on Sep 26, 2009
projdoc
  • 2237 Answers
SOURCE: I have a Toshiba TDP ET20 projector, the problem
if the fans come on but no lights, listen for a high-pitched whir. if you don't hear it, the colorwheel needs to be replaced. if you do hear it, replace the ballast. if no fans, replace the power supply.
Posted on Nov 11, 2009
  • 23 Answers
SOURCE: Replaced bulb in projector and it still doesn't
Smetimes the other fan comes on when set to full bright. As your lamp is not lighting up, the other fan will not come on. If yo have replaced the lamp and it is still not working, then 9 times out of 10 it is will be the ballast.
Posted on Jan 21, 2010
Projector will not turn on from standby
Hi, did you ever get an answer to your question? I have an ET20 which, after several months of non-use, has now stopped working. The standby light is on, it makes a startup 'noise' but then does nothing. None of the other buttons are illuminated. Is this similar to your problem?
Dec 29, 2013 | Toshiba TDP-ET10 DLP Projector
Hello, if I want to hook up an external audio device such as a speaker to my Toshiba TDP-ET20 DLP Projector, how do I do that?
Hey,
You will need to buy a digital coax to an RCA or analog Headphone cable. You will plug the digital coax end of the plug into your "coax out" connection on the back of the project.
The other end will depend on your speakers. If your speakers take an RCA connection (white and yellow cables) then you will buy a Digital Coax to RCA cable. If they take a regular headphone jack then you will need a Digital Coax to 3.5mm headphone jack converter, and plug the headphone jack into your speakers.
Mar 01, 2011 | Toshiba TDP-ET20 DLP Projector
Projector over heats while watching a movie. it just powers down without doing its usuall cool down exercise. maybe its a power issue but the temperature coming out of the projector is very hot.
I would check and make sure that the vent area is clear of dust. The vent being blocked with dust would cause the temperature to rise very fast while the projector is on.
Feb 26, 2011 | Toshiba TDP-ET20 DLP Projector
I have a Toshiba TDP ET20 projector, the problem is that there is that it wont power up. There is a click when the power is turned on but no lights, including the main projector light, come on
Nov 06, 2009 | Toshiba TDP-ET20 DLP Projector
Sep 26, 2009 | Toshiba TDP-ET20 DLP Projector
Remote not working
Check the batteries in both remotes.
May 27, 2009 | Toshiba TDP-S8 Multimedia Projector
Lost manual
The manual is available online quite easily. Just google.
As for the audio connection, this is one big drawback of the TDP ET20. it only has digital audio out so you can't connect it directly to headphones or ordinary speakers. You need a home theatre system or an amplifier that accepts digital audio. Or you need to buy a seperate digital to analog audio converter.
Big pain.
Jan 15, 2009 | Toshiba TDP-ET20U DLP Projector
Will not turn on at all
you will probaly needs a new power supply in it. make shure that your getting power from outlet to. Hope this helps
Jan 13, 2009 | Toshiba TDP-ET20U DLP Projector
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-ET20U DLP Projector Logo
239 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
