Question about Intel Motherboard
Problem with the screen
The surface of my screen has a long crack,liquid spash through the crack,its laptop of hp type,what solution is there to rectify the problem.
    Genius:
  • 1,102 Answers
Think your gonna need a new screen
sometimes cheaper to buy a new laptop
Posted on Jan 17, 2009
Sony pcv-rs520 boot bios - need BIOS entry key for changing boot drive
Should be the F2 key to enter setup. Make sure you are pressing this key during the VAIO spash screen on boot. If you press it after the spash screen the bois will not load and you will have to power cycle the computer to get the spash sreen back and try again.
Feb 20, 2012 | Computers & Internet
Broken lcd, how can we go about it.
Call HP to determine if the unit is still in-warranty, and they will be replacing it. Otherwise, you may have to upgrade it through their Out-of-Warrranty programs.
Feb 13, 2011 | HP Compaq Presario V2555US Notebook
My hp pavillion laptop will not show a picture is there anything I can do
If everything seems to be working normally except the display is always black and never even shows the BIOS screen, try shining a flashlight on the screen at an angle. If you see part of the picture (it will be dim and low contrast), you have a bad fluorescent lamp tube or inverter.
If you do not see a picture, you may have a cracked solder connection under the video chip. Several of the HP Pavilion laptops made in the last couple of years have acquired a reputation for thermal failure of the video chip solder. Repair requires some knowledge of surface-mount rework techniques. If you are game to try it yourself, post back and I will describe the procedure, but bear in mind that you will need an anti-static work surface, a hot air gun and liquid solder flux. An infrared thermometer would also be highly desirable for best results.
To prevent the problem from happening again, make sure you keep your fan and the radiator clean and avoid blocking the vents while using it. Do not use the laptop on a carpet, blanket or upholstery. Don't rest the center-back area of the bottom on your leg; that's where the graphics chip is located. People have acquired permanent burn marks on their legs from the hot spots on their laptop computers. (The processor is a couple of inches to the left, it's the other big hot spot.)
These are the worst-case scenarios. If you see the BIOS screen, the Windows startup screen, then nothing but black, suspect a virus infection such as the ThinkPoint scam.
Jan 19, 2011 | HP Computers & Internet
Cracked the LCD screen on an HP 2530 Elite laptop, replacement screens available, please?
Go to www.ebay.com type laptop, the make and model, and screens, this will give a list of sellers and pricing.
Jan 07, 2011 | HP EliteBook 2530p Notebook
LOOKS LIKE SCATCHES BUT THE SCREEN ISN'T SCRATCHED AND BLOOBS OF LIQUID ON THE INNER SCREEN. A LINE DOWN THE CENTER OF THE SCREEN TOO
That really sounds like the LCD screen is cracked. The front will not feel cracked because of a clear plastic cover sheet but behind it is the LCD panel. The liquid you see is part of the screen leaking. The LCD actually means "liquid crystal display" and that is what you are seeing leak out between the cracks in the panel. You will need to have the panel replaced to clear the problem. You can get the panels from Ebay if you want to do the repair yourself. This type of repair is not covered under the Acer warranty. If you have any questions just use the email address below.
Buddy
Corporate Computer
www.ccl-la.com
h@ccl-la.com
Dec 16, 2009 | Acer Aspire One PC Notebook
Gouge in laptop screen. Less than half inch long
Hi:
is the display distorted under the scratch?
If it is, the problem could get worse. If your scratch is just on the plastic surface, the problem shouldn't get worse.
Oct 29, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion DV9500 laptop with rainbow of lines on screen
Yes There are several layers that can crack and you may not feel it on the surface
Apr 29, 2009 | HP Pavilion DV9500T Notebook
Liquid spash on Samsung LCD monitor - now won't power up.
It can ruin your computer. Act quickly if this happens, because it only takes seconds for liquids to destroy the hard drive of a laptop computer.
Step One
Shut down the computer immediately.
Step Two
Wipe up any liquid. Tilt the computer to the side to drain any liquids.
Step Three
Remove any removable parts from the laptop, including the power cord, printer and mouse cables, the floppy drive, CD drive, modem cards and battery. Do not disassemble the laptop body to remove internal parts.
Step Four
Once the parts are removed, gently lift the computer and turn it to the side and upside down to drain any liquid. Tilt the computer in a variety of directions to verify that there are no pools of liquid lurking, but be careful not to shake it or handle it roughly.
Step Five
Repeat with the floppy drive and other removable parts.
Step Six
Use a hair dryer on a cool setting to dry the laptop and its parts if you can.
Step Seven
Allow the computer and its removable parts to dry for 24 hours before you reassemble it and turn it back on. (If you are under a tight deadline, let the laptop dry for at least an hour before you reassemble it.)
Step Eight
If the computer does not work properly or does not turn on, bring it to a computer repair professional, although the damage might be irreparable. Spills are one of the leading causes of laptop deaths.
Jan 21, 2008 | Panasonic Toughbook 17 PC Notebook
Intel Motherboard Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
