How do I use motorola bluetooth H500 with razor phone?
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your bluetooth headset pops up on the list, highlight it and press ok to connect.
your cell will then ask permission to bond with the phone, select yes. It will then ask your for a pin. The pin will be 0000.
This is what I tried so far...
Make sure your earpiece is compatible with your phone.
1. Charge your earpiece.
2. Go into the menu on your phone.
3. Go into Settings.
4. Go into Connection.
5. Select Bluetooth.
6. Choose Handsfree.
7. You will either see Motorola H500 listed (if you previously synched) or you will have to choose [Look For Devices].
8. While it is looking for devices, hold down the "Call" button on your H500 (it should have a phone icon on it) for two to three seconds and then let go.
9. Your phone will tell you when it has connected to your headset. The reset/bond code is standard for most Motorola phones: 0000
But still is not working...
cannot find bluetooth
I get power to the BT just fine but the phone (LG Blackberry) cannot find the device, the BT H500 I am trying to use is kind of old and could be the problem but I don't know how to test it to make sure, please help.
