Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
MS Vista user//appdata/roaming HUGE
110 Gigabytes. How do I clean this ****** up? It's taking up 1/3 of my hard drive!!!!!
  • ljaygould Jan 17, 2009
    Chris:
    Thanks very much for introducing me to nCleaner. With all the garbage programs out there professing to clean the Reigstry, etc. and "Free Download" and then they hold you for ransom ("only $29.95"!!!) to actually DO the work this one's a breath of fresh air!
    The only reason I didn't choose Fixya!! was that after running this I needed to find the files that were taking up the OTHER 100G after nCleaner did its work, but this was a lot easier with all the garbage cleaned up: Adobe Creative Suite 4 seems to like to put files with a .cfa extension in a Media Cache directory that are as big as the files where I am actually working on the projects, and then not cleaning them up...some files were as large as 15G (an SD video capture of a 4-hour opera before editing - imagine if it was in HD!!!) In any case, thanks.
  • 827 Answers
You have to be careful you don't manually delete anything important. Better to use nCleaner, download, install, run. Do a 'Clean System'
and then go back and 'Shred Free Space'.
That will recover quite a bit of space.
Hope this helps
Chris (ziraffa)
Posted on Jan 17, 2009
It says that "Your Auto
You can check out this link:
http://social.technet.microsoft.com/Forums/en-US/office2007deployment/thread/c1b0a32f-fbdf-42af-af7c-f0cccd798d5a/
or
-open RUN or search
-type "REGEDIT" on the run or search box
-navigate to
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
-Check if the Appdata value has a value, if not right click on the blank side choose New >> Expandable String Value then type "AppData" - without quotes
-right click on the value that was just created and choose Modify and type
"%USERPROFILE%\AppData\Roaming" - without quotes
Then restart..
AppData
REG_EXPAND_SZ
AppData
REG_EXPAND_SZ
AppData
REG_EXPAND_SZ
Mar 24, 2011 | Computers & Internet
For Vista it is C:\Users\yourusername\AppData\Roaming\ wear i want to find
these folders are hidden so unhide first then you can find the folder. and you can open my computer and type the hole syntax ie. C:\Users\yourusername\AppData\Roaming\ on the above address bar.
Jan 22, 2011 | Intel Computers & Internet
We took still photos while we were on Skype, but how do download them to our hard drive/picture files?
In Win 7, skype images are stored here (by default)
C:\Users\your-user-name\AppData\Roaming\Skype\Pictures.
Note : The AppData is hidden by default.Make sure you use the correct user name, and you allow viewing of hidden folders.To show the hidden files do the following
1. Open Windows Explorer
2. Click the ORGANIZE drop-down box at the top.
3. Click "Folder and Search Options"
4. Click the VIEW tab.
5. Click "Show hidden files and folders."
Nov 30, 2010 | Computers & Internet
How to install the magic jack to window 7
To magic jack its works fine in windows 7, you should do the following things:
1. Copy the mjusbsp folder from a working install on XP or Vista to the C:\Users\UserName\appdata\Roaming folder in Windows 7.
2. Start it the no splash way to make it to load "C:\Users\UserName\appdata\Roaming\mjusb... ck.exe" /scf _magicJackPersonalDataRoot X:\magicJack
What's more, at the time of installing magic jack, do right click on the exe file and select the "Troubleshoot Compatibility". A window showing that Windows is testing the software. After completion it shows "Try recommended settings". Click on this settings that you will use. Click the "Start the program". Follow the on going instructions.
Nov 28, 2010 | Computers & Internet
Error 1606
Re: Please Help Unable to Install TIVO Desktop -- Error 1606. Could not access network location %APPDATA%\
The response to "Echo %appadata%" should be
C:\Users\UserName\AppData\Roaming
A space in the user name shouldn't be a problem, but creating a new user may fix the problem because it will create the account with default registry settings which will hopefully have the missing %appdata% information.
If you want to check on this before creating the new user, just for curiosity's sake, check the following Registry key:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders and check the value for AppData in the right hand pane. If it's missing, then that would explain the problem. It should be as listed above, substituting the UserName with the folder name for the user under Users.
Also check the key
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
The value of this key should be
More keys to check:
HKCU\Volatile Environement (1)
HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Volatile Environement (1)
The values in (1) should have the full path spelled out, the values in (2) should use the %USERPROFILE% variable in the path. If the value under HKU\.DEFAULT is missing or bad, then creating a new user probably won't work either. If that value is missing, then I would recommend a clean reinstall of Windows because there is no telling what else is messed up also.
The value for AppData in the registry key HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
is C:\Users\Murray Admin\AppData\Roaming
In the key the key
The value for AppData is %APPDATA%
The value for Local AppData is %USERPROFILE%\AppData\Local
In HKCU\Volatile Environement (1)
The value for HOMEPATH is \Users\Murray Admin
In HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value for AppData is %USERPROFILE%\AppData\Roaming (all the keys have the %USERPROFILE%\ )
In HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value in one of the \Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\UserShell Folders keys for AppData is
%APPDATA% (Missing the %USERPROFILE%\ ) --- Could this be the problem???
All the other values within do contain %USERPROFILE%\
Do you think editing the key, adding %USERPROFILE%\ would do the trick? If so, it would be alot eaiser then
a re-install. There is not much junk on it as this pc is only about a month and a half old. The other machine
is about six months old. Both are from the same manufacturer (Compaq) but different models.
Also - Using the set command the value returned for %APPDATA% are:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Murray Admin>set
TEMP=C:\Users\MURRAY~1\AppData\Local\Temp
TMP=C:\Users\MURRAY~1\AppData\Local\Temp
Jan 20, 2010 | HP Computers & Internet
Getting error code 1606 no acdess to network location %APPDATA%
%appdata% is not a network location. It is a systemwide variable
%appdata% it is a directory on your computer
for XP it is C:\Documents and Settings\yourusername\Application Data\
I think the application is having problems locating it.
Nov 22, 2009 | Computers & Internet
Trying to install office 2007 but keep getting error code 1606 cannot find network location %APPDATA%. What can I do to fix this?
To resolve this issue, follow these steps:
  1. Click Start, click Run, type Regedit.exe, and then click OK.
  2. Locate and then click the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  3. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 7. For Windows XP and for Windows Server 2003, see the following table. Collapse this tableExpand this table Value name Type Value data AppData REG_EXPAND_SZ %USERPROFILE%\Application Data Cache REG_EXPAND_SZ %USERPROFILE%\Local Settings\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\Local Settings\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\Local Settings\Application Data Local Settings REG_EXPAND_SZ %USERPROFILE%\Local Settings My Pictures REG_EXPAND_SZ %USERPROFILE%\My Documents\My Pictures NetHood REG_EXPAND_SZ %USERPROFILE%\NetHood Personal REG_EXPAND_SZ %USERPROFILE%\My Documents PrintHood REG_EXPAND_SZ %USERPROFILE%\PrintHood Programs REG_EXPAND_SZ %USERPROFILE%\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\Start Menu Startup REG_EXPAND_SZ %USERPROFILE%\Start Menu\programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\TemplatesFor Windows Vista, see the following table. Collapse this tableExpand this table Value name Type Value data {374DE290-123F-4565-9164-39C4925E467B} REG_EXPAND_SZ %USERPROFILE%\Downloads AppData REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming Cache REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\AppData\Local My Pictures REG_EXPAND_SZ %USERPROFILE%\Pictures My Music REG_EXPAND_SZ %USERPROFILE%\Music My Video REG_EXPAND_SZ %USERPROFILE%\Videos NetHood REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts Personal REG_EXPAND_SZ %USERPROFILE%\PrintHood PrintHood REG_EXPAND_SZ %USERPROFILE%\Documents Programs REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
    Startup REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
  4. If any Name, Type, or Value does not match the table in step 3, right-click the Value name, and then click Delete.
  5. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 3, and then press ENTER.
  6. Right-click the value that you created in step 5, click Modify, type the value in the Value data box for the Value name, and then click OK.
  7. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  8. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 12. Collapse this tableExpand this table Value name Type Value data Common AppData REG_EXPAND_SZ %ALLUSERSPROFILE%\Application Data Common Desktop REG_EXPAND_SZ %ALLUSERSPROFILE%\Desktop Common Documents REG_EXPAND_SZ %ALLUSERSPROFILE%\Documents Common Favorites REG_EXPAND_SZ %ALLUSERSPROFILE%\Favorites Common Programs REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs Common Start Menu REG_EXPAND_SZ %ALLUSERSPROFILE%\Start menu Common Startup REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs\Startup Common templates REG_EXPAND_SZ %ALLUSERSPROFILE%\Templates
  9. If any Name, Type, or Value does not match the table in step 8, right-click the Value name, and then click Delete.
  10. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 8, and then press ENTER.
  11. Right-click the value that you created in step 10, click Modify, type the value in the Value data box for the Value name, and then click OK.
  12. Exit Registry Editor, and then restart the computer.
Sep 04, 2009 | Microsoft Windows Vista Home Premium with...
C:\Users\toshiba\AppData\Roaming\fyxegtbu.dll
You have Malware or Spyware. If you can load your destop, download and run http://malwarebytes.org and http://www.spybot.com. If you can't load your desktop, download (including updates) from another computer and run on your desktop. Good luck.
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
Takes a huge hardisk space
Actually You need at least 40 gigabytes minimum for Vista to work well. The only thing that You can do is to format the hard drive, and re-install Vista with at least 40 gigabytes available in its partition.
Jan 11, 2009 | Microsoft Windows Vista Ultimate Edition
ArcSoft TotalMedia 3
esponser(Zoe) 11/2/2010 1:01:34 AM
Hello Nick,
Thank you for using our products.
Regarding your issue, please try to reinstall your TotalMedia 3.5 following these steps(before that, please make sure you keep the original installer):
Step1: Pull out your device and uninstall from Control Panel -> Programs -> uninstall TM, restart PC
Step2. delete these files/folders:
W7 32-bit OS:
C:\Users\current user\AppData\Roaming\ArcSoft
C:\Users\current user\AppData\Local\ArcSoft
C:\Users\All Users\ArcSoft
C:\Program Files\ArcSoft
C:\ProgramData\ArcSoft\licensedata
W7 64-bit OS:
C:\Program Files (X86)\ArcSoft
Step3: Clean up the registration files:
1).Go to Start menu and click "Run", type "regedit" and press Enter.
2).Delete [HKEY_LOCAL_MACHINE\SOFTWARE\ArcSoft] and [HKEY_CURRENT_USER\Software\ArcSoft].
Step 4: Reinstall TM after rebooting the computer.
Hope the above can be helpful.
Thank you for your understanding and interest in our product.
Regards,
ArcSoft Support
Jan 16, 2008 | Computers & Internet
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
95 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
