Question about Polaroid FLM-2601 Television
Motor of 28 years old washing machine
Motor name plate: S.O.L.E. S.p.A.ODERZO-TREVISO ITALY
TIPO 20570.67 1-Mot.50Hz
ISOLAMENTO CL.F 220V
S2 10min 3,3A 2800 1/min 150w 10uF 450VL
S2 60min 1,3A 430 1/min 70w 10uF 400VL
VDE 0530 -1/11.72
this motor is of QUELLE, Privileg-C25 washing machine No.74704.
the controler of the machine has gone bad. I want to use the motor manually, motor have 5 leads ,Brown,Gray,White,Pink,Blue. Which lead to connect where, to use it manually for slow & fast speeds,also the reversing function,also please spesifications of Capasitors, in other words, the wiring diagram for this motor & any advice / instuctions please, thank you.
  • zafar_70 Jan 17, 2009
    MY eMAIL for the above is zafar.70@hotmail.com pl.
  • zafar_70 Jan 18, 2009
    Thank you for your email, but my query (as above) is related to a 'MOTOR' of awashing machine & not to any Polaroid etc. Please, thank you.
2 Suggested Answers
  • 3 Answers
SOURCE: Replace Capasitors
Just start removing all the visible screws , The power module with the bad capacitors is the unit in the center , Wasn't rocket science to find it either , Just follow where the power cord connection at the tv goes to which board
Posted on Sep 08, 2008
Can i use a 50hz 220V SPLIT TYPE AIRCON TO 60HZ 220V
you probably can but it will be damaged over time, you would need to replace the motor inside to handle 60hz using the 50hz can do damage to the motor, or even cause a fire. also if it has a power capacitor that asys 50hz on the power line to the unit inside this would been changing as well.
Jun 29, 2017 | Heating & Cooling
How to operate a AEG Washing Machine Electrolux 50hz with 60hz power supply?
In general, it is NOT recommended to operate an appliance 50hz-to-60hz OR 60hz-to-50hz UNLESS the manufacturer specifically says it can do it.
Additionally, you must also account for the voltage (110V vs 220V), which you have not indicated.
Therefore, it is best to get your exact model number and contact the manufacturer, but get ready for disappointment. The larger and more complex the electronic device, the less compatible it is.
Good luck.
Mar 19, 2015 | Electrolux Washing Machines
Sir, I would like to ask if this samsung washing machine model Diamond Drum WA80V3 220V - 50Hz - 330W can be use in Cebu City, Philippines where the electricity power cycle running is 60Hz?
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
Jun 17, 2011 | Samsung Washing Machines
The fan will not turn on.i have 110v to circit board on the unit, the unit is one year old. it is a colmon mack 8000
check the name plate of fan motor if it is 220V or 110V,if 110V but still not running replace the fan motor.
Jun 05, 2010 | Dometic Rooftop RV Air Conditioner
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
110V 6ohz - 220V 50hz
Kitchenaid mixers are not recommended on the use of a converter as they are not tested under such conditions. Understanding this, using a convertor on your mixer may automatically void the 1 year warranty regardless of age.
There are international Kitchenaid dealers available if you are requiring 110V. You may contacted Kitchenaid Customer Service for more information.
Their toll-free telephone number is 1-800-541-6390.
Jun 23, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Elektra Microcasa a leva
You will need a 120/220V transformer for starters. That will make the Italian coffeemaker compatible with American outlets. The good news is that you can't do harm by plugging a 220 into an American outlet - it will just not give you enough power to run the machine.
I doubt that you can still get parts - I've seen used ones that still work on sale for anywhere from $1,000 to $3,000 - not cheap.
Here is all the contact info for Elektra - they are definitely still in business:
Elektra s.r.l. - Italian Espresso Coffee Machines
Via A. Volta 18, 31030 Dosson di Casier (Treviso) Italy - Tel +39 0422 490405 - Fax +39 0422 490620
Url: www.elektrasrl.com - Contact: info@elektrasrl.com -
Mar 11, 2009 | Elektra Microcasa S1 Coffee Maker,...
240v 50Hz Zanussi zwf14581w wont start code EH1 with 220v 60Hz
EH1 is a fault code that relates specifically to the frequency of the electrical supply. The power board is designed for 50Hz and will notice if it does n't get what its looking for.
You may be able to purchase a new main PCB that works with a 60Hz supply. You would need to contact Electrolux to ascertain whether this would be possible.
Nov 23, 2008 | Zanussi ZWF1430W Front Load Washer
Where can I order a new belt for my Zanussi IZ12 wasmachine?
bit of a nuisance doing it from afar but i have used currys masterpart ( a uk site) for ordering spares now i'm retired
Nov 12, 2008 | Zanussi IZ12 Front Load Washer
Polaroid FLM-2601 Television Logo
77 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
