Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell lcd monitor 193fp
It power up for 3 seconds only
    New Friend:
  • 90 Answers
Power board needs replaced
Posted on Feb 08, 2009
I have a Dell 193fp monitor. It's 5 years old and is used infrequently. Today the Power button started to flash amber repepatedly while making a slight clicking noise. After turning it on and off,...
This sounds like the power capacitors are failing, which is not uncommon for a monitor of this age. You can take it to a TV repairman and get the offending capacitors replaced, however, the cost of replacement may outweigh the cost of a second hand monitor
Jan 22, 2011 | Dell E193FP 19" LCD Monitor
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
Dell LCD screen - powers up...i see the log on then black
I guess your monitor needs some maintenance.
Have it checked by a technician
Mar 28, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E153FPd Power stays on but video goes off after 2 seconds.
3 ideas here. bad connections on the coils inside. the inverter board has gone bad, or bad capacitors on the power board or inverter board. all of witch should be serviced by a qualified service center.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
I have dell 1907fpt, the lcd screen powers up for just 2 or 3 seconds.
The backlight might be bad. As far as I know, there isn't a way to replace that, so you'll have to get a new monitor.
Jul 17, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell model No. 1504FP will turn on for 3 sec then off
THE PROBLEM IS THE MONITOR IT SELF.
IT IS TIME TO BUY A NEW MONITOR. I KNOW ALOT OF OF US CANNOT AFFORD A NEW MONITOR EVERY TIME ONE BRAKES, I HAVE FOUND THAT SECOND HAND STORES SALE THERE MINITORS FROM 1-2 DOLLARS PER INCH, I PICKED UP IBM FLAT SCREEN 20" AROUND 20.00 USD. AND IT STILL RUNNING AND I HAVE HAD IT FOR A YEAR OR MORE NOW.
May 12, 2009 | Dell 1503FP 15" LCD Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Power cord for Dell Monitor 2005FPW
I got this from the website at Dell. It looks like the cord you want is the second one. I'm basing this on the fact that normal operating wattage is 55w with a max of 74w and that would describe your second cord. The first one wold provide too much power.
VESA Modes
Horizontal Sync
Vertical Sync
Video
Power Indicator
Power Consumption
Normal operation Active Active Active Green 74 W (maximum)*
55 W (normal)** Active-off mode Inactive Inactive Blanked Amber Less than 3 W Switch off - - - Off Less than 1 W(at 110 Va)
Dec 26, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell E193FPC
Looks like your inverter board is broken.
Similar problem as Neovo F-417 (same chassis) , Look for 715L1283-4 inverter board
Try http://lcdpartsandrepair.com/e193fpc-inverter-power.html
Jun 26, 2008 | Dell E193FPC 19" TFT LCD Flat Panel...
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
157 people viewed this question
Alun Cox
