Question about Xerox 8830 Copier
Xerox xc830 My copier is dark on one side and light on the other. I replaced the drum and toner. I do not know what else to check.
  • 2 more comments
  • Sue Cogger-Muscanera
    Sue Cogger-Muscanera Jun 22, 2007
    Thanks> I tried that still did notwork.
  • Anonymous Jan 21, 2008
    My problem is similar but the entire page comes out completly black.
  • Anonymous Mar 13, 2008
    perhaps too much powdered ink produce that strips of black is on the paper like 70% top to bottom of the paper. The remaining side of the paper appears normal.
  • Anonymous Mar 14, 2008
    Ink will not fuze on paper XC830 copier
  • 4 Answers
Try taking your toner cartridge out and knocking on it over a garbage can and then put it back in...sometimes the toner clumps up in the cartridge from sitting.
Posted on Jul 06, 2007
  • 186 Answers
Try cleaning the optics under the glass.
Posted on Jun 21, 2007
6ya staff
SOURCE:
Dark streak on copies
Drum, wiper, or fuse rolls. Pull out toner unit see if you can see those lines.on the drum.
Jan 16, 2014 | Xerox XC830 Copy Machine Refurbished
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
I have a Xerox XC820. I am getting dark copies with residual images from previous copies. Toner appears to be adhering to the drum cartridge. Do I need a new drum cartridge?
I have a Xerox xc820. The drum kit needed to be replaced, which I did as well as put in a new toner cartridge. The pages are now coming out very dark. Prior to putting in the new drum kit and new toner cartridge, the machine ran fine. I have tried all I know how to do and to no avail. Have cleaned the "wire", all the parts I can get to and cleaned the plate. Any help would be appreciated.
Apr 21, 2012 | Xerox Office Equipment & Supplies
My Xerox XC830 copies are dark and have lines but otherwise present the image. How can I make the background white again.? Thanks! Ron
You probably needs some servicing. Drum, developer and other parts have a life cycle and once it's exceeded you can start having copy quality issues. Unfortunately there is no easy fix.
Jul 03, 2009 | Xerox Office Equipment & Supplies
My copies have a thin line from top to bottom that is very light to no print at all. The thin line is at the same place every time but the rest of the copy looks great. I have replaced the drum and toner...
You probably have some thing in the developer unit, if you take out the developer and check the bag roller and brush, if you slowly turn the dev unit you might see a void area that is being passed onto the drum.
If the developer has a large numbers of copies on it then dump the developer and replace the starter.
Make sure the developer get thoroughly cleaned especially behind the blade.
If the developer is not all that old, then lift the blade off and clean the backside of the blade, and the area or areas of the brush that have the void.
Hope this is of some help.
Ed
May 09, 2009 | Xerox 5100 Copier
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
590 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
