Question about Samsung LN52A850 52 in. LCD HDTV
The picture on my LCD 52" 650 series TV makes everyone look short
People don't look natural - they look squatty and fat. How can I fix this?
  • 11,896 Answers
There is an aspect ratio setting in your menu options. You will have to change the aspect ratio so you get a normal screen.
This will most likely fix your problem.
If by slight chance it doesn't, you will have to remove the back of the tv and find the manuyal adjustments for it.
All newer Tv's have the aspect ratio/picture change setting.
Posted on Jan 17, 2009
Tv has sound but no picture
check your lcd lap drive to see if you have power to the lamp drivers
Nov 19, 2013 | Philips 52PFL5403/98 Series 5000 52-Inch...
I don't get a picture only sound is that a major repair and worth getting fixed?
No picture with sound is commonly problem of LCD TV. The cause of that problem is the back light is not working,because the back light inverter board is deffective,maybe there's a blown surface mounted fuses cause of shorted transistor, transformer or bad capacitor.That the coomon problem of no display LCD television.Hope it will help you.Thanks..
Sep 03, 2011 | Olevia LT27HVX 27 in. LCD Television
HI i have a acer X193HQ 18.5LCD MONITOR it fell off from my hands and now i am having two vertical lines one is ofblue color and another one with white colour. can you tell me how to fix it. I...
You may have damage the connection between the T-CON board and the LCD panel.
I would try reseating the ribbon cable between the T-CON board and the logic board, if that does not fix the problem, you will need new LCD panel.
See example here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/albums/yy352/budm/ACER/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 19, 2011 | Acer X193W LCD Monitor
The picture images are fat and squatty, particularly people! Can the picture be adjusted?
Search the remote for a button that says "format" or "aspect ratio" or maybe "display." You're looking for 4:3 aspect ratio. This will probably give you bars on the sides of the pic and is usually only adjustable on analog.
Apr 05, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Pictures and icons look squatty How do I make them look normal?
change your resolution. depending on whether its a widescreen or not, this can make pictures look squatty. if its widescreen, generally 1400x900 is a good resolution. on regular ones 1280x1024 is generally good. but that also depends on what size ur screen is also
Jul 30, 2009 | Computers & Internet
I have sound, but no picture. The screen is a faded blue or green
It sounds like you need a new LCD screen. That should fix the problem. They are very easy to install, just make sure you get a SHARP brand, and also be sure to get it for the right model. Currently three different types of LCD screens, one for PSP 1000 (original fat) models, one for PSP Slim (2000) series, and Slim 3000 series. They run about $50-$75 but should fix your problem. Hey it's cheaper than buying a new PSP right?
http://www.shopzilla.com/psp-accessories/sharp-psp-lcd-screen/9611/products
Aaron
Jun 12, 2009 | Sony PlayStation Portable (PSP) Console
I have an Orion TVD 2710. Need to adjust resolution.
if you have a menu button on tv shoul be able to do it there after you push the menu button then use the up or down button for selection then the volume up or down to ajust then menu to exit. Now if no menu button sometimes you can push the up down chanel button at the same time and get into the menu. Hope one of these works.
Feb 20, 2009 | Orion STV2763 27" TV
Picture looks stretched, people are squatty looking
You may only need to change the format for the picture. Check your owners manual for how to change the picture format, or aspect ratio. The tv may be in the zoom mode the way you describe it. There is likely an option in the menu to allow the unit to automatically set the format based opon the signal being received. Only some of the programming you see is actually HD. The Super Bowl was broadcast in HD and has a 16:9 aspect ratio (width to height). When this set is adjusted for a correct HD display I'm confident you will be impressed. So I believe this is a matter of a customer setup with the remote. If I had the unit in front of me I could offer more detail. I hope my general opinion helps.
Feb 02, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony dp26648 tv
I would like to help you but I do not know what squatty is
Jul 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung LN52A850 52 in. LCD HDTV Logo
401 people viewed this question
Jerry Greenberg
Jerry Greenberg
