Copiers
Problem for Ricoh Copiers
Generic problem for all Ricoh Copiers
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
By sternblicker on Jan 17, 2009
on our MP 2510 the error code SC 541 has appeared. I've replaced the thermistors of the fuser, but the SC 541 keeps appearing, although I've resetted it by executing SP 5810 in service mode and power off/on.
I've built in a spare fusing unit, a new one, also with new thermistors. With that fusing unit the error SC 542 appears always, also after resetting by executing SP 5810. Toner was'nt fixed on the page before this error appeard.
So I have SC 541 with one unit and SC 542 with the other unit, reproducable.
I've also checked this technical service bulletin: http://www.standleys.com/SERVICE/Bulletins/8025-30/8025%20fuser%20SC%20codes.pdf. The therein mentioned screws are ok.
What could cause the error? Something else beside the fusing unit?
Thank you for advice!
Stefan
Best Solution
posted on Jan 17, 2009
Very Helpful)
jrmicallef
Rank: Guru
Rating: 91%, 64 votes
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 02, 2009
Very Helpful)
Stefan_K
Rank: Apprentice
Rating: 100%, 2 votes
On our MP 2510 I've solved SC 541 by changing thermistors (part no. AW10 0053) in the fusing unit and clearing the error in service mode.
When I had SC 542 I've checked the thermostats with an ohmmeter/resistance meter, one had high resistance and had to be replaced. After replacing this thermostat (part no. B209 4095) and clearing the error code the copy machine was working again.
Stefan
TeXblog.net
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Mar 26, 2009
Not Rated)
daddymangoe
Rank: Apprentice
Rating: 0%, 0 votes
my sc542 has aproblem its telling me contact service prep mo972000160 has appeared on the screen what shall i do
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
sir a gestetner 5340 copy printer wair cut by rat so kindly sent me poin to point circuit diagram.... (More)
Answer
how to setup a eStudio 210c to work on a network. Do you plug it into the router or a PC? How do you... (More)
Answer
I install the cartridge then machine was warming and show the code F2
Answer
i can not print AR-M 161 for vista, i have parallel connection ,and i can not find GDI Driver for... (More)
Describe your Copiers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
