Question about EliteGroup ECS Motherboard MB K7VTA3 Socket A AMD XP DURON SEMPRON (796791550175)
I get BIOS ROM CHECKSUM ERROR during bootup, then SYSTEM HALT
I get this error "BIOS ROM CHECKSUM ERROR" on bootup followed by a "SYSTEM HALT".
I've tried removing the battery CRXXXX and replaced it back but still the same message occurs.
I also tried to reset my CMOC by the jumper switch but same results occured. can you advice some help?
    President:
  • 1,257 Answers
Click on the link below to know more about the issue and how to fix it
http://winhlp.com/node/192
Posted on Jan 17, 2009
Bios rom checksum error, boot block bios vI.0
Error BIOS ROM CHECKSUM - SYSTEM HALTED.
Cause Bad Hardware
Solution Unfortunately this indicates that your computer BIOS ROM chip or Motherboard is physically bad. It is recommended that you contact your computer manufacturer or take the computer into local service center for repair.
If you wish to repair this issue yourself the motherbard will need to be replaced.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Apr 14, 2012 | ASUS A8N-E Motherboard
One short beep one long beep continuous and power green led flashes continuos
I would say you have a failed memory (RAM) module. Probably a module in one of the secondary slots since the computer is able to POST and will attempt to boot.
Mar 20, 2012 | HEWLETT-PACKARD Computers & Internet
Maxdata tower computer : - when switched on bleeps 2/3 times and doesn't engage the mouse or the keyboard and the monitor shows " no video input ".Just no response and doesn't turn itself on...
BIOS Beep Codes
Whenever a recoverable error occurs during POST, the BIOS displays an error message describing the problem. The BIOS also issues a beep code (one long tone followed by two short tones) during POST if the video configuration fails (a faulty video card or no card installed) or if an external ROM module does not properly checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors, usually consisting of one long tone followed by a series of short tones. For more information on the beep codes issued, check the documentation for that external device.
There are several POST routines that issue a POST terminal error and shut down the system if they fail. Before shutting down the system, the terminal-error handler issues a beep code signifying the test point error, writes the error to I/O port 80h, attempts to initialize the video and writes the error in the upper left corner of the screen (using both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to the operating system.
I hope this helps.
Mar 14, 2011 | Computers & Internet
Bios rom checksum error.. system halted
This error comes when there is low cmos voltage so motherboard flash memory forgot the bios settings.
For that open cpu and then pull cmos cell from mother board buy new cmos cell and replaced it.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios and set time and date and boot option in bios then save settings.
Then it works again if it not works then you need to update firmware for your bios .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 07, 2009 | Foxconn K7S741MG-6L Motherboard
I can not access my computer because it comes up with a stop error
as your machine is booting, press F2 or Del key repeatedly, which will get you into system BIOS. Then go through the BIOS settings page by page until you see something glaringly wrong or highlighted.
You should also be able to disable system halts for such things as keyboard and mouse errors, with an 'all errors' setting as well, but use that one with caution, in case it's not something simple.
Note: If you continually get 'checksum error', or if your date and time keep resetting every time you reboot the system, your motherboard battery is shot and needs to be replaced.
Oct 21, 2009 | E-Machines emachines (emachinees) CD-ROM...
Computer wont boot up
first reconnect your keybord and mouse jack in computer then power up the compter then press del or F1 or F2 to nweter in bios setup then just press F10 and save settings .
Feb 07, 2009 | Dell Computers & Internet
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Bios checksum error. How to solve it?
If you are using an old computer, there’s a possibility that you already encountered this error message during bootup; “CMOS checksum error – Defaults loaded”. At this point, the PC will halt its operation and requires you to press F1 to continue or DEL to enter setup (mostly but also depends on motherboard) to proceed.
This is caused by incorrect or corrupted CMOS values. BIOS settings are stored in CMOS. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, the error message will be displayed.
For most cases, this is caused by the motherboard battery. Buy a new one to any electronic retailers in your area and replace it. Turn on your computer and press the stated key to enter the BIOS setup. It can be DEL for some or F2 but this depends on your computer. On the BIOS menu, try to change the DATE and TIME settings because their values are reset to different value. Most settings are set to default so leave it as it is. Save the settings and reboot your computer.
Oct 04, 2008 | MSI PM8M-V Motherboard
Bios ROM checksum error
The rom you used to flash the bios may not have been the correct one for your mobo, or it did not complete the flash entirely. Try using the usb a drive to flash it again and/or revert back to an older version.
Aug 01, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
My ecs p4vmm2 cannot open to windows
you must have a faulty floppy disc unit, you need to press F2 or Del to get into the bios and check the time and date if they are wrong then the cmos battery needs changing.
Sep 11, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup ECS Motherboard MB K7VTA3 Socket A AMD XP DURON SEMPRON (796791550175) Logo
372 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
