Question about Samsung SCX 4521F All-In-One Laser Printer
SCANNER PROBLEM WHEN WE PUT THE PAPER IN THE SCANNER FOR SCANNING OR PRINTING TE PAPER COMES OUT BUT IT HAS A BROAD BALCK STRIP ON THE PAPER SO PLEASE HELP US TO SOLVE THIS PROBLEM
  • SOSworkshops Jan 26, 2009
    When I send a fax a broad stripe covers the sheet of paper on the receiving end.
  • Anonymous Apr 05, 2009
    When I use the feeder to scan or photocopy the copies come out with a black line just past the middle of the sheet. The roller appears clean and in good working order.
    Sergeant:
  • 326 Answers
The problem with the roller check it out
Posted on Jan 17, 2009
Ir 3530
please cleen your scanner home position sencor
Jun 30, 2013 | Canon ImageRUNNER 3570 Copier/Printer
Get a black strip when I try to copy or fax a paper. Able to receive a fax without problems. Replaced drum and cartridge and cleaned what I could see, but strip is still there.
sorry but the drum has nothing to do with the SCAN problem, only for PRINTING problems, if you have a BLACK STRIP when you scan, you must check the SCANNING lamp for obstruction (liquid paper contaminant) on the scanning window or for other debrie that prevent the scanner to scan properly is it a dual feed??? (flat bed or top load)???
Apr 09, 2011 | Brother Office Equipment & Supplies
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
When I am faxing to someone my outgoing fax comes through with a line running down the middle. How can I fix this?
Hi. Try to open the cover for the scanner bed. You'll see 1 big glass and 1 small strip of glass on the left side. The big glass is used for scanning using the scanner bed. The small strip is used when paper is going through the feeder. Wipe the glasses thoroughly with a soft cloth. Hope it's just a dirt that's causing the problem. Good luck!
Mar 11, 2010 | Lexmark X5495 All-in-One &USB...
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Dark balck line down middle when copying, but not when printing
If this happens only when you feed the original through the top feeder and not when you lay it on the glass, then you have a small bit of dirt at the scanning location--since the paper moves, rather than the scanning bar, the section of glass that is involved is very small and one little bit of dirt will make a line down the whole page. You need to lift the automatic document feeder mechanism and clean the glass strip under it--that's where your (unseen) dirt is. (Page 108 of the manual, if you have one.)
Dec 10, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Scanning
Open the top Auto Doc Feeder. (The area where you insert the original to copy) It lifts up when pulled up gently but firmly. You will see a strip of glass. Clean the glass strip with Windex or alcohol on a paper towel or rag. Put the cleaner on the rag, not sprayed on the machine so it doesn't get on unwanted areas. Carefully examine the glass as you have smudges of ball point pen or white-out on the glass.
It appears as a line because the paper is moving past the fixed scanner and it can scan through whatever you have on the glass.
Hope that helps you. :)
Sep 30, 2008 | HP LaserJet 3050 All-In-One Printer
Lazer not scanner
If I am not mistaken you are getting blank paper when you give printing command am I right if yes........
every laser printer has one data scanning and transferring data to toner drum unit in it.
BLANK PAPER PRINTING PROBLEM ONLY LINKED WITH
1. TONER CARTRIDGE PROBLEM OR
2. SCANNING UNIT OF YOUR LASER PRINTER PART OF YOUR LASER PRINTER.
CHANGE TONER IF PROMLEM IS SAME THEN IT IS CONNECTEE TO SCANNER OF YOUR LASER
IF NOT SOLVED MAIL ME TO inkcity@rediffmail.com
Jun 01, 2008 | HP LaserJet 1012 Printer
Facing copying problem from scanning section
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
Apr 09, 2008 | Office Equipment & Supplies
Samsung SCX 4521F All-In-One Laser Printer Logo
101 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
