Question about Car Audio & Video
Caste code - Car Audio & Video
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Pls post back to confirm if you are in need of the security code of the car stereo. If yes, the code may be found:
  • inside the owner's manual;
  • the dealer who would require the VIN and proof of ownership.
If not, pls clarify your requirement.
Good luck and Thank you for using FixYa.
Posted on Jan 17, 2009
    President:
  • 1,257 Answers
Provide some more information regarding the issue so that experts from fixya can resolve it quickly..
I have not been able to use a chromecast with my tablet
you need to setup chromecast on a pc. and connect through the wifi to to the cast. setup the cast for your wifi and i.e it will ask for the wifi code or the sink to be activated. then any device connected to your wifi will work the cast. you do need a google account to log the cast. your device will need the chrome cast app installed for it to work as well
Jul 15, 2017 | Samsung Televison & Video
Chevy engine block identification numbers V0710FSC TEJ528846
Small Block Chevy Engine Block casting and code identification
www.nastyz28.com/sbchevy/sblock.html
Sep 14, 2012 - Small Block Chevy engine identification. Code identification, Casting Number info.
Chevy Casting Number identification - Block casting numbers
outintheshop.com/faq/casting/castings2.html Chevy Casting Number identification including Block casting numbers, cylinder ... 2-bolt Chevy II Nova Recessed filter .... 2 & 4-Bolt Mexico cast Crate engine.
Reference: Chevy Engine Block Casting Numbers - Chevy ********
www.chevyhardcore.com/news/reference-chevy-engine-block-casting-numbers/ Sep 19, 2013 - The engine block casting number for both BBC and SBC engines is found at the back of the block where the transmission mounts to the engine.
Chevy Identification Numbers - 73-87.com
www.73-87.com/chevy_ids/sbcid2.htm If you have a small block Chevy engine, and need to identify any parts you have laying around, or maybe the engine that is in your truck, I think you will find the ...
Chevrolet - Browse - Casting Numbers .info: engine blocks, heads ...
www.castingnumbers.info/site/browse/m/chevrolet 12562932, Category: Cylinder Heads Type: Big Block V8 Date: 1991-1995. Notes: oval port, open chamber, Gen.V, truck crate motor, 118cc chambers gm chevy ...
http://outintheshop.com/faq/casting/castings2.html
Jul 04, 2017 | Cars & Trucks
I have a GM 350 I can't identify. Casting number is 14093638. Date code is J284. Engine ID is v1117pjf. Engine VIN is CSE131557.Both head casting and date codes are 10110810 L094.
Casting # 14093638
87-95 350 Car & Truck 2 & 4-bolt Passenger stick 1-piece seal
Oct 25, 2016 | GMC Cars & Trucks
Thanks for the help I just noticed my typo my casting numbers are 3858180 my apologies the engine is a 1965 327 I just cant seem to find what kind of car it was put in if anyone has any suggestions on were...
"You need to get the suffix code off the front pass side, on pad in front of the head. It will be a code thats 6, 7 or 8 digits long. The 1st one will be a letter, next 4 will ne bumbers and last 1, 2, or 3 will be letters.. Like say V0621KH. V0621 if the prefix which tells plant, mo. and day, KH would be the suffix code which tells engine size, HP, induction system, and car it was used in Your 3858180 is not a vin #, it's the casting number and no it does not decode as a corvette. The casting # does not tell what car it was installed in. Its just the size and year range. That # is added before the engine was ever thought of being built and installed. 3858180....327...1964-67...2 bolt main thats all the casting number decodes as."
Aug 06, 2014 | Cars & Trucks
LOCATION ON ENGINE NUMBER OF KIA SPORTAGE 2005 MODEL
Find the engine identification tag. Attached at the factory, this tag is normally found on the engine block around the coil bolts. The top line of the tag identifies engine size and model year.
Search the block for the engine block casting number. The numbers are raised, not stamped into the block and consist of seven numeric digits. The digits can be located on either side of the block. The seven-digit number may be followed with a dash and further numbers. These are change codes and are not normally necessary to identify the engine.
EX.:
Locate the casting date is located on the block. It is in standard date coding, 2.25.93, for example and may be located on either side of the block, but is commonly located on the driver's side of the block, above the freeze plugs. The example 2.25.93 decodes as February 25, 1993. The casting date may be near the casting clock, which designates the hour the block was cast. Magnum engines were manufactured from 1993 to 2002, so verifying the date code helps identify the engine.
Jan 15, 2011 | 2005 Kia Sportage
What are the engine codes and what do they stand for? ie: Y= 400 C.I. engine,325 h.p.
What kind of Pontiac engine you have? Is it pre-80's? Pontiac engines have a 2 letter stamp on the front top passenger corner of the engine block. The year is usually next to the distributer hole, and the actual casting number is located on the top rear of block. Some sites offer casting number searches. A good one is wallaceracing.com. They deal with everything from block and cylinder head numbers. If the engine is 1970 or newer, engine size is casted behind the dipstick passenger side of block and also on the front driverside of block too. There are many different variations of codes to list. A example it the engine is made in 1967, casting number is 9786133, code on the right front of block says YE, then it's a 1967 400, that originally had a automatic transmission connected to it, had 10.5 to 1 compression, #066 camshaft, 143 or 061 cylinder heads, 4bbl carb, and 325 horsepower.
Dec 19, 2010 | Pontiac GTO Cars & Trucks
Code to convert number to string in SQL
You could use a combination of the CONVERT and CAST functions to cast the number as a money type, then convert it to a varchar, and then strip off the decimal point and 2 0's at the end: DECLARE @test int SELECT @test = 12345 SELECT REPLACE(CONVERT(varchar(50), CAST(@test AS money), 1),'.00','')
Regards, ploysandy
Jun 26, 2010 | Computers & Internet
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
