Question about LG Studioworks 563N 15" CRT Monitor
PC is not working in 1024*768
Dear Sir,
My pc is not working in 1024*768 display mode. Monitor is studioworks 563N, operating system is win Xp.
Requsting you to kindly give me solution.
  • Sameer Raut
    Sameer Raut May 11, 2010
    you have mention the display settings & u r saying ur pc is not working u have not mention properly whether ur monitor is not working or ur CPU .......................... brief ur problem again
  • 827 Answers
Download Belarc Adviser, install it and run the program. This will tell you lots of things about your computer, Under "Display" it will tell you what kind of graphics card you are using.
It will probably be ATI or nVIDIA. Download and install the latest driver for your card. Be careful that you install the correct one.
For example, if it says nVidia, go here for the latest driver.
After you have installed the latest driver for your graphics card, you can change the display settings to work in 1024*768.
You do this by right-clicking on the desktop and clicking Properties. You will find the settings there.
Hope this helps
Chris (ziraffa)
Posted on Jan 17, 2009
LG studiowork 563N desktop bottom screen is getting dark but sometimes it works. i set brightness full but still its dark. Please help.
Hi, It could be you need a new V-card. or your monitor is on its way out. My bets are on the monitor. Good luck.
Sep 15, 2011 | LG Studioworks 563N 15" CRT Monitor
Lg 500g monitor blinking in bi-color, no display when powered up
Sir,
there could be two possibilties for that
1 That your serial cable is not working or have broken pin .
2 Another is that you monitors picture tube has got damaged or burnt.
Usually it is second reason it can be repaired but is more expencive so i would prefer buying new one.
Nov 08, 2009 | LG Studioworks 563N 15" CRT Monitor
Video and images too dark
You can try this. Open the cover (Unplug the monitor and leave at least for 30 minutes before doing this). See whether dust is there. If there is dust, get a 1" paint brush and gently remove the dust with the brush. Always sweep the dust away from the unit. If black dust is present around certain cables and around the flyback transformer (that black box covered with aluminium plates), use a soft cloth to wipe them (do not wet the cloth). *Make sure you dont turn those rings on the back of the tube while wiping the the dust. After cleaning the dust, replace the cover, connect it to the PC and check. You will have a brighter picture!
Jun 01, 2009 | LG Studioworks 563N 15" CRT Monitor
Menu button of my monitor is not working properly
Try to fix that on display setting under windows display setting set it on lower setting. You can do that alternatively by booting on safe mode. Then readjust your display setting.
Mar 08, 2009 | LG Studioworks 563N 15" CRT Monitor
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
My monitor changing green display .
1.First U can check any dry points in video section (Neck board).
2. check VGA cable
Aug 11, 2008 | LG Studioworks 563N 15" CRT Monitor
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Nov 18, 2007 | LG Studioworks 563N 15" CRT Monitor
Lg 563n monitor problem
Plz check your monitor's vga cable for ok .I think there is problem in 1,2,3 no pins wires continuity.If it is ok then check components thats are connecting these pin to video amp. ic on crt neck.If they are ok then change video amp. ic with new one.Hope this solution works otherwise i am always ready for help
Sep 10, 2007 | LG Studioworks 563N 15" CRT Monitor
Peculiar Problem in LG studioworks 563N monitor?
Is there anything going on in Control Panel, Power Settings? Such as an auto off? Sometimes getting the monitor to come back on after it goes to "sleep" can be tricky. Usually a keyboard stroke works better than mouse movement. It almost sounds like a hardware problem and I would contact the manufacturer and see if it's still under warranty. I'm assuming the PC it is connected to isn't going off?
Mar 28, 2007 | LG Studioworks 563N 15" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
102 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
