Question about Whirlpool LSQ8243H
Whirlpool Lsq8243h After loading the Wahser, the water comes, and then the motor starts, but it wouldn't spin. It tries, but then start making noise. It only happened tonight when I think I loaded the washer with more than I should have. I have done this in the past and don't think that it would break the motor. Seems like that something stuck inside, but I don't have to remove the part that spins and moves the clothes around inside the wahser.
  • abbasa_ali Jan 21, 2009
    Sorry for the late reply as I was out. Actually, I did that but didn't
    find any belt at all. Is the belt supposed to be all the way down
    near the edge. I couldn't get underneath the round plate. Any other
    suggestions will be appreciated.
    Best Reards
  • henebry Mar 15, 2009
    My Whirlpool washer, LSQ8243H, makes a clicking noise, but will not agitate or spin. It still fills with water and the pump still drains the washer.
    There is no belt on this machine that I can find. The motor housing appears to be connected directly to the spinning drum.
    The drum will not move when I try to move it with my hand. Perhaps there is something stuck inside, but I THINK that the drum doesn't move manually even when the machine is working properly.
    Any ideas?
You are correct, there is no belt on this model. it is a direct drive. The motor drives a gearbox that attaches directly to the drum. Mine is having the same problem and I'm lean toward the gear box being bad.
Posted on Jun 28, 2009
  • 3 Answers
Unplug washer and lean washer back aganst wall,put something under frount of washer.So you can see under washer .Look and see if the belt are still on the pully or if there streached out (not tight) fix accordingly.
Posted on Jan 17, 2009
Fills with water and then stops makes a humming sound ,then stops all togther wont do aything spin or drain
sounds like an induction motor. start winding or start capacitor not starting to turn motor, This will make motor hum. Do not know m/c in qestion. Switch on and as soon as pos try to turn motor careful not to use hands or anything that can injure yourself with if it starts to spin.
Oct 29, 2012 | Whirlpool WTW5521S Top Load Washer
Whirlpool lsq8243h
If it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills up and starts. Once it gets to rinse cycle and spin cycle is makes a loud humming noise but wont spin. If i open the top lid and wait a second or two and close it, it starts the cycle. Been...
If you have a direct drive washer made by Whirlpool, your washer transmission has what is called a neutral drain built into it. It is designed to pump water out before it starts to spin. After water has drained out, the timer has a pause in it where motor shuts off for about 5 seconds. When motor comes back on, transmission is then in gear to spin. If timer never pauses, then washer never goes in gear to spin. Timer is most likely defective.
Sep 14, 2017 | Whirlpool WTW5100S Top Load Washer
LSQ8243H does not agitate and spin after water was filled, but pump the water out. What is wrong?
If you hear motor running, then probably bad coupler. Lately I have been seeing more and more bad transmissions in these.
Aug 28, 2010 | Whirlpool LSQ8243H
My LSQ8243H filled up with water and stopped.
sound's like you have a bad motor.
Nov 18, 2009 | Whirlpool LSQ8243H
Water refills after a complete cyle. GHw9100L
Had similar problem and ended up being the valve. Try shutting the water off to the wahser during the spin cycle. If the water doesn't refill, that is the issue.
Mar 28, 2009 | Whirlpool GHW9100L Front Load Washer
Water supply
yes it is normal. It fills up during the washing proces
I had the same thought at first but it truns out ok.
Jun 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
175 people viewed this question
Dan Webster
Dan Webster
Sal De
