I was switching around my power supply and once i hooked all the cords to my motherboard and such all the feedback i got once i pressed the power on was a single blink on the power LED light ... the 24 pin cable once i press it nearly all the way in my fans power up but once i press it completely in and turn the power on it only blinks once and doesnt do anything PLEASE HELP im in college and i really need to get my homework done its a priority!!!
  • pablosinche Mar 30, 2009
    i loose the power in the computer..when i opened, i tried to verified if the wires was tighten but i disconected and i forgot the right position...there are thre pair of cord one H.D.D LED, other is POWER SW, and the third one is POWER LED. Can you help me?... the computer model is emachines T6520
  • Michael Lucas
    Michael Lucas May 11, 2010
    Is the other power supply new.... If not it could be bad!
    Also make sure you are trying to plug the main connector in backwards... Sounds silly but I've seen it done. Match the lock on the side of the connector with the clasp on the motherboard socket.
    If neither is the issue let me know.
  • 1,102 Answers
Your not getting power
did you loosen the power button wires from the motherboard
Posted on Jan 17, 2009
Came home to find it off, tried to power up, fan runs 3 seconds, no power light, then off
Try first to unplug the power cord at the back of the CPU then press the power button for 5 seconds while the power cord is unplug. This will clear the remain power from the capacitors on the power supply. Once done, re-connect the power and try to power the computer back on.
If still not, then this is a power supply issue. What you can do is to open the case, make sure power cord is not connected and you have done the above step again to ensure that there is no electric current remaining. Once done, trace the connection from the power supply connecting to the motherboard and unplug it. Please check for the lock clipping it from the motherboard. once removed, again press the power button for 3 seconds. Then reconnect everything and power the computer back on.
If still not, then this is really a power supply issue and it should be replaced.
Aug 09, 2011 | eMachines ET1641-02w (PT.NA60X.001) PC...
Gateway 500s power box when hitting test button powers both fans, but no power to hardrive, dvd, or monitor. I have replaced power supply, motherboard, and harddrive, I have nothing, but green power button...
Does the fan on the power supply run? As you say the power on switch lights up and so does the motherboard, means that the power supply is working. Monitor gets power from the socket on the power supply. Try plugging it in the wall socket. Try to unplug the main power cord from power supply to the motherboard. The one that has a broad plug at the motherboard end. Replug it and they power on the PC.
Sep 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
My dell GX260 had a problem. I had taken the cover off and removed the slave switch and also removed the main cable running to the motherboard but forgot to remove the power cord. Once I plugged the cord...
Try to go back and place everything the way it was But always and foremost alwyas unplug the power supply first. once everything is back to it original state U plug it back . But always the Power plug should be the last part u connect. What is it that U were trying to do
Aug 12, 2010 | Dell Computers & Internet
Gateway computer 310 series wont power up when
It sounds to me like the power switch is plugged into the motherboard incorrectly. I would need to know the type of motherboard you have to get you the proper schematic for hooking up the power switch and reset switch to the board. If you have the manual to the motherboard, there should be a detailed picture showing you how it is to be hooked up. Please let me know the motherboard model for further assistance.
Good Luck,
Jan 29, 2010 | Gateway 310 S PC Desktop
Doesn't power up, power light flashes 3 times when power button is pressed
Hello mate,
check that:
1. power supply is connected correctly to the electricity and from the other side to your laptop. 2. there is normally a light on the power supply, make sure that this light is one. in case it's off, that means the power supply is broken. 3. There is a charge light on the laptop which should be on once you connect the power supply to the laptop even tough the laptop is off. if this light is off, that means: a. the power supply is not passing the current to the laptop: you may test with another power supply. b. the power connector on the laptop is broken.
In the worst case, the motherboard maybe broken.
Oct 29, 2009 | HP Pavilion dv9000z Notebook
Fans run without turning on front switches
Hi Gene,
If you've installed the cpu and hooked the fan to the power supply plug, which is just left of the cpu mount, then the board if connected to the power supply cables, it should start up. Regardless of the front switches. However, you probably don't want to start plugging in the power cord until you have all of your components in place and ready to close up the case. First you can create a shock by just touching the board and that can damage the board. (I speak from my own experience :-( .
But once you get the power switch plugged into the board that should take over turning the rear power supply on and off (Including the cpu fan)
Good Luck and don't forget to leave a rating, based on my solution.
Thanks Mark
Apr 16, 2009 | Intel D865PERL Motherboard
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
Power problem
look for a switch on the back of the computer by the power supply it must be in the I position not the O . if that will not work then the motherboard my be damaged or the power supply itself not the cord for it is very rare for a power cord to polarize any more. last the power button itself may be damaged but in al my years I have not found a bad power button yet. Always it has been the motherboard or the power supply.
May 08, 2008 | E-Machines eMachines Desktop PC
P4vmm2 motherboard wont start
cheak and change ur power supply
Jan 05, 2008 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
