Question about Westinghouse LCM-19v1 Monitor
My 17 inch lcd monitor will not turn on
I just got my cpu unit repaired and got it back home and plugged everything in, it all lights up except the monitor does not turn on and I can't find manual...i have one main cord from the monitor to the cpu unit..i am pretty sure that i hooked it up right...please help my monitor is 2 yrs old and i have not used it for two months while my computer is being repaired
  • 4 Answers
This is most likely the capacitors on the power board in the monitor, if your comfortable wkith opening it, and good with a soldering iron, etc
then you can most likely fix it, just look at the CAPs and you'll probably see them fat! or some gew on the top of them!!
Posted on Feb 05, 2009
With the unit turned on, turn off the lights and with a flash light shinning at the LCD screen, do you see any images ?
If so, the Back lights or inverter have gone south.
That is a cheap 17" unit and would not be worth the repair cost.
Jan 25, 2014 | Sharp LL T17A3-H (Gray) 17" LCD Monitor
Monitor won't display. Everything is plugged in and power is on
Might not getting any signal from the source ,you will have to try your cpu else where with same vga cable to figure out whether its your monitor or your cpu tower.
Sep 02, 2011 | AOpen F2705 17" LCD Monitor
I have a ADMNLCD20 monitor a the cash register of my convenience store and it has gone dark. All the control lights are on at the bottom front of the monitor. I disconnected power from the unit and...
rdsellers54, Can you see very faint image on the lcd panel if you shine a very bright flashlight 1 inch from the panel at different angles? Yes = 5v dc supply ok, lcd 12v dc not ok. No = 5v dc and 12 vdc not ok. You or technician will need to check units "switch-mode-power-supply / CCFL power supply dc rails first. This display no different than any other cold cathode fluorescent lamp back-lit lcd monitor on the market today. May be of interest for you to see some video clips of lcd monitor SMPS being repaired at YOUTUBE by their owners/technicians and noting the main culprits responsible for "black screen of death" symptom!! Then do some rading of FIXYA profiles of "budmrtn" and only the higher numbered profile pages in my profile. 12fixlouie
Nov 14, 2010 | American Dynamics ADMNLCD17 17 inch...
Unplugged monitor. left home for a couple of days. Plugged monitor in and got no picture. Turned CPU on and off and the CPU does recognize it, but still no picture. the monitor power button just flashes.
Try it on another PC, if it still does not work and you want to DIY repair, please read below and look at pictures.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 08, 2010 | Samsung 931BF 17" LCD Monitor
17 inch IBM Thinkvision
Well... a good way to tested the caps is to used a Blue ESR meter.
Oct 04, 2008 | IBM ThinkVision L170 17" LCD Monitor
It is a dell 17 inch monitor
The logic board on the LCD panel itself goes out a lot on that unit. If you have everything but a picture then that is the problem. Rub your finger on the screen if you see light behind your finger but no picture then this is definently your problem. If there is no light then your inverter is the most likely problem. sells all parts for that unit.
May 01, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell monitor problem
hey buddy, its seems to be the display driver problemi think..
please install the correct display driver for your VGA card in the CPU.. let me know?
Dec 13, 2007 | Dell E173FP 17" LCD Monitor
Blinking Blue Light.. >.>
check for loose connection of the video cable connection on the system unit (CPU). blinking may indicate that there is no signal transferred from the cpu to the monitor!
Nov 04, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
Sony Monitor ... SOMEONE HELP, please!
Thanks for your response. I actually sent my monitor out to guy that does LCD repairs for cheap. He changed out the video board and did repairs similar to yours but still couldn't get the monitor to work. After some more testing, he found that one of the chips that contained Sony's proprietary firmware had gone bad and said there really was no way to replace the chip. It definitely seems like we had the same problem, so I thought this information may help. I'm sorry that you paid so much for repairs that didn't solve the problem.
May 14, 2007 | Sony SDM-HS73P 17" LCD Monitor
Westinghouse LCM-19v1 Monitor Logo
181 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
