Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
How do I set the clock on our Foster oven?
Power went off, and we don't have an instructions manual (We are in rented unit.) There are 5 buttons to push: bell (timer); pot with steam; pot with an X; a plus; and a minus. Would appreciate your help.
SOURCE: We have a Belling oven that we can't turn on.
We solved this by pushing both the "start cooking" and "stop cooking" buttons at the same time (these are the ones showing a pan with steam coming out of it and a pan that says stop above it). While holding these down we used the plus and minus buttons to set the time. After doing this we were able to turn the oven on.
Posted on Oct 26, 2009
SOURCE: smeg oven SE399X/5 - digital clock issue
I'm glad I'm not the only one either - in the end I bought new buttond from smeg service/parts centre on their website. I took apart the front of the oven and re-seated the clock. I pushed in the new buttons and now its all ok. My problem was that because the clock had mis-lodged the buttons were touching the metal at the front of the oven, and like you when the grill is on the metal gets too hot and melts all the buttons. So the clock has to be in exactly the right place or it will melt the buttons so much that they will not press in...what a bummer!!! :-)
Posted on Jun 15, 2007
SOURCE: FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Posted on Sep 14, 2007
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
barkencoa
  • 3463 Answers
SOURCE: Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Posted on Dec 08, 2009
My power went out came back on but my digital display is not working for clock and oven. Is there a reset button?
when the power goes out The display has to be reset, clear instructions will be in the owners manual , most instructions change from model to model. so check the manual.
Jan 03, 2018 | Ovens
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
The actual temperature of my oven does not agree with what it says on the digital readout in the clock area. I have been told that you can adjust the reading of the clock, but I cannot find the service...
Press bake and set temp. to highest setting on some it's 500 on others it's 550 aftef setting to highest bake setting. Press and hold bake button until 00 is displayed,use up/down arrows to adjust in 5 degree incriments to plus/minus 35 dergees . ONce you've adjusted it push cancel/off button and you adjustment will be stored even if power loss and clock went out.
If your temp is more than 35 degrees off the clock needs to be replaced
Aug 16, 2011 | Ovens
Westinghouse oven pof668 in auto mode - how do I get it out of auto mode (am renting this property). Oven and grill are not working as power was off until recently
Most models won't work when on Auto. Generally there are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). Press this button and it should go back to manual mode and allow you to use the oven.
What I have said so far is pretty much a guess, based upon experience. I'm also guessing that you don't have a manual to refer to either. However, w
hile I can't find the specific manual for your model, there is a westinghouse oven manual here:
http://manuals.appliancesonline.com.au/westinghouse-dualfuel-ovens/westinghouse_duelfuel_ovens_manual.pdf
and I would bet that the clock setting instructions on page 18 are exactly the same for your appliance!
Jul 28, 2011 | Ovens
How do i reset the time clock on a simpson evolution 912
Can you add a full model number? I am having trouble finding the manual from the information given. From other oven manuals from simpson, it sounds like the clock is programmable when power is first supplied, so unplug the unit, wait a few minutes, and plug it back in. Then press the - and + buttons to set the time. 5 seconds after the last change the time will be set.
Oct 03, 2010 | Ovens
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
Dacor ecs230 clock button is not working
there may be a backup battery built in to this unit to keep the clock running in case the power goes out. depending on the age of the unit, it may need to be replaced. the battery size and number as well as it's location should be in the owner's manual.
Aug 25, 2009 | Dacor ECS230 Epicure Electric Double Oven
Time display
if the-at doesn't work sounds like you inadvertently turned of the display for clock try holding the clock button for 3-5 secs itll beep and remain on then
Mar 09, 2008 | KitchenAid KEBC247 Electric Double Oven
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
254 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
