Question about Clarion DRB2475
Manual I need the wiring dio for the Clarion DRB2475
  • dkmaverick Aug 23, 2008
    I need the wiring diagram DRB2475, however all my wires (16pin) all white. I would have to have the number of the pin and its function.
    Thanx.
  • 41 Answers
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
To see the actual pin-out assignments for the wiring diagram of the Clarion DRB2475, go to
http://clarion.com/us/en/support/product_bulletins/index.html
and scroll down to “Source Units” & click on‘Source Unit Harness Applications” which brings up a PDF page containing thepin-outs for a variety of Molex connectors, including TWO distinct versions forthe 16-pin connector. In order to figure out which version is correct, remove the bottom section of the metal chassis on the DRB2475, which simply pops off with a little prying, and then examine the circuit board near the 16-pin connector. The DRB2475 unit I examined labels most of the traces on the circuit board so one can easily determine which wiring diagram is correct.
Posted on Oct 14, 2008
SOURCE:
Need to know wire color for memory function on clarion car stereo
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Jun 23, 2010 | Clarion DRB2475
I need a wiring diagram for a clarion drb2475 car cd player
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
May 02, 2010 | Clarion DRB2475
Clarion DRB2475 mutes when I turn up the volume
Sound like one of your car speakers is faulty, try using the fader and see if it still happens when all sound is to the front or rear and try left and right.
Nov 16, 2009 | Clarion DRB2475
Clarion drx6275gv clock
I have tried all of the above solutions, but none of them worked! Does anyone else have another solution? Cheers.
Jul 06, 2009 | Clarion DRB2475
Clarion 3475 speakers wired, player wont turn on
The RED from the clarion wire must be hooked up to a switched power source ... that was wired to your old radio, then press the reset switch, and it should then turn on.
May 05, 2009 | Clarion DRB2475
Wiring on a Clarion
power wire is red,mem wire is yellow, dimmer will be orange or orange w/ white line in it, and the amp wire will be the one that shows 12volt power only in the on posision (blue) if it has two the other is for power ant.
Jan 12, 2009 | Clarion DRB2475
Automatic Antenna
sounds like a new aerial is needed, if noone has messed with the wiring...
get someone to turn on the radio while you listen near the aerial...
if it sounds like it is making an effort to work then it could be the nylon runner...
if it doesnt make a sound check the power & earth connections at both ends, behind the stereo & at the antenna.
some have 3 wires power,earth & switched.
some only a switched & earth.
Dec 27, 2007 | Clarion DRB2475
Setting the clock
The DRB3475 is similar and you can download the manual at http://www.clarion.com/us/en/MungoBlobs/82/1021/DRB3475(Manual).pdf
Hope this helps.
Feb 13, 2007 | Clarion DRB2475
Car Audio & Video Logo
1,560 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
