Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Furnace shutting on and off every four to five minutes all day
I have a 3 year old Gibson furnace. It's very noise and it's always cycling on and off . It fires up for 4 minutes and cools down air for 3 minutes. This is the cycle 24 hrs a day. It never stops. Is this normal? The current temp, outside is 9 degrees and the inside temp is 67 with the thermostat at 75. I replaced the thermostat and has not resolved the problem. Can anybody help or provide advice .
    Scholar:
    New Friend:
  • 70 Answers
Have you had furnace cleaned? Have you changed filter or took filter out and try heater? Have you checked return grill to make sure you don't have anything in front of it. Return grill or duct could be blocked or two small. Blower motor could be going off on thermal overload. Does the heater do the same thing when it is 20 degrees outside. The other thing it could be is furnace is not big enough.
Good luck let me know what you find out
Posted on Jan 18, 2009
Have Gibson furnace runs cycle but seems don't get hot enough out of vents check all 115 degrees at vents use to lot hotter old furnace you couldn't stand on vents now you can easily
Is this a gas furnace ? Newer high eff. gas furnaces do have cooler outlet temperatures. The installer should have checked the temperature rise and gas pressure. By adjusting the gas pressure and blower speed you can obtain a higher outlet temp, but you don't want the gas pressure to be higher than the manufacture specs and you don't want the furnace to run outside of the manufactures temp rise specs.
Mar 02, 2017 | Gibson Heating & Cooling
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
My furnace is 4 years old. It cycles but does not ignite
More info is needed.
When you say it "Cycles", where does that fall into the following sequence....
1. Call for heat
2. Inducer starts(exhaust)
3. Pressure switch closes( connected to inducer via hose)
4. Ignitor glows or sparks
5. Gas valve opens and burners light
Does the ignitor glow or spark at all?
Do you see the exhaust working?
Sometimes the small hose that runs from the exhaust housing to the pressure switch will get clogged. Blow it out and don't forget the inlet and outlet.
Feb 16, 2015 | Gibson KG7TC060D24B 60,000 BTU 95.1% Gas...
Amp fuse keeps blowing
The component being protected by the fuse is drawing excessive current - has to be a board or something because the motor always draws more than three amps. Check the units schematic for locating the possible offending board. Must be relatively new since you indicate it is multispeed. Still under warranty?
Feb 23, 2014 | Gibson KG7SA045C23A 45,000 BTU 80% Gas...
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
My Gibson Furnace clicks on but no heat comes out.
After four years I do not thing you have an effective warranty even if the company still in business. you need to open it first and clean it from any builod up dust and check the switch to see if it is working (thermostate)
Nov 08, 2009 | Heating & Cooling
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Heating & Cooling Logo
184 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
