Question about HP Pavilion tx1000z Notebook
HP mini notebook (Linux) won't login due to GDM/full memory prblm
When logging in the following message shows up; GDM could not write to your authorization file. This could mean that you are out of disk space or that your home directory could not be opened for writing. In any case, it is not possible to log in. Please contact yoru system adminstrator.
How do I fix this...?
I forgot my password my omnibookxe3on windows for
If you forgot your password and the answer to your security question then no, you won't be able to login with that account.
There are free tools on the internet that you can use to reset your password with. Search for linux based windows password recovery tool and you'll get a long list of them.
Depending on the version of windows there is a boot option that at the windows loading screen you can press F8 to login as the system administrator which you can reset the password for your user account from there.
Jul 03, 2012 | HP OmniBook XE3 Notebook
Tip
Auto login in Ubuntu Karmic
Ubuntu 9.10 comes with GDM
(GNOME Display Manager) a graphical login program.
This is default login manager in Ubuntu 9.10.
If you, have wish, to login automatically in Ubuntu
instead of the manual login
that you choose in the installation process, we have the new possibility.
Configure GDM to auto login a specific user:
(1.A)
Applications> Accessories> Terminal
When you open this copy it (when you ask for your password, type):
gksu gedit /etc/gdm/custom.conf
Enter the configuration values that you want to override:
AutomaticLoginEnable=true
AutomaticLogin=laikexpert
(Save changes and close custom.conf)
(1.B)
Reboot your system, and you’re automatically logged in to Ubuntu.
on Jan 23, 2010 | Computers & Internet
What is the problem regarding a mini hp notebook that cannot booth but it has a power
It can be a due to a faulty memory , a hard disc or if the OS comes up and then the PC hangs , it can be due to a virus.
This can cause havoc to your PC and corrupt files that are needed to work the PC. If so the OS- operating software - must be reloaded.
Oct 09, 2011 | HP Mini 1000 Netbook
How to unlock password for a HP 2140 Mini-Note
If you are talking about the login to Windows password then here is one way to do it:
Create a bootable USB stick using this tool: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Use the image from Ophcrack to load onto the USB: http://ophcrack.sourceforge.net/download.php Choose the XP LIVE CD Option
1. Download the YUMI exe to your desktop 2.. Save the LIVE CD of Ophcrack to your desktop. 3. Plug in the usb stick you want to use (make sure it is at least 500MB. 1GB if possible) 4. Run the YUMI EXE and follow the instructions. Make sure to choose the USB Drive Letter ("D:" E:" etc) 5. Choose the Ophcrack ISO for the image. 6. Install to USB 7. Click Finished and exit the program and close any other open programs. 8. Restart the computer. Leave USB plugged in. 9. As soon as the computer restarts, tap the F10 button to enter the BIOS Menu. 10. Scroll to the Boot / Advanced Menu and change the boot order to USB first, HDD second. 11. Save and exit BIOS. Computer will restart. 12. Once booted up the computer will bypass the HDD and boot into the USB 13. elect Ophcrack from the list and hit Enter. 14. Follow the on-screen instructions to have Ophcrack force the password.
(If you're using Linux then use the Linux LIVE CD Image instead of XP)
May 03, 2011 | HP Mini 2140 Notebook
I was given an HP Mini 1120NR netbook as a gift. The system came with Linux OS installed. My system crashed due to a power failure while I was restoring my system and simulatneously charging my battery,...
first error is step on, never install OS with bad or dead battery
rule 1. so why not stop now and do step one right.
if battery is bad it must be removed and replaced.
as most are this old. ,never seen own old battery like this still good.
This LP stink, have one new parked in attic. hated it.
love Linux do but had the slug processor.
1.60 GHz Intel Atom Processor N270
see that processor, its not a real Intel top class processor
its toy grade.
this mini is setup to boot 2 ways
1 is ROM linux inside
and 2, vista?
mine has a rom imbedded Linux in it that runs using alt boot mode.
but is hard coded in the ROM.
called RESIDENT LINUX. (or techs call it Embedded)
is that failing? or the DVD OS failing?>
the note book can have
ROM LINUX (for ever, its in A CHIP, not HDD)
+ boot hdd linux. boot hdd, XP or Vista.
as you can see you could have 2 linux,
one in rom, and newer one in HDD.
but many linux made do not support the silly ATOM processor.
which OSs are you attempting.
why not buy the HP media kit installs.
https://support.hp.com/us-en/drivers/selfservice/hp-mini-1100-pc-series/3875650/model/3860343
here is the driver pages
the media kits are there too.
ask more questions, i played with mine awhile., before parking it.
the claim to fame on this unit
is hDD turned off
boot to rom LINUX and battery lasts 10 hours
can cruse web and read email, on ROM.
very crafty idea but processor is stinker.
maybe ill put in an SSD and see if it can run faster. next winter
Apr 09, 2017 | HP Mini 1120NR PC Notebook
It says "GDM could not write to your authorization file. This mean that you are out of disk space or that your home directory could not be opened for writing. In any case, it is not possible to log in....
I assume this is linux? if your home directory can not be found you may need to format that particular partition with gparted, if you want to try something prior you can try and use kanotics or mepis live cd and try and transfer the data to a different device or back it up online.
Oct 02, 2009 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
Memory full
Hii
Bro i suppose u might hav cleared msgs from ur sim memory and not phone memory. Anyways if the problem still persists , then try getting ur cellphones software updated from Moto Service center, Its done for free if ur still un warranty.
regards
Sep 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Hp mini notebook ran out of memory and i cant access the internet
create a usb boot pen with your orduring boot time press F8 and choose security mode, reach to your hard disk and delete all trash you know you don't need, then shutdown the system and restart usual way.
Apr 14, 2009 | HP Pavilion dv9000z Notebook
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Computers & Internet Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
